2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 2016 528 leaking coolant from lower pass side wheel well
      08-10-2023, 06:27 PM   #1
jmmdm2
Drives: 2015 528i xdrive M-Sport
2019 BMW M550i  [0.00]
Checked the typical issue with the expansion tank, it’s dry all around. Performed bleed procedure, noticed a decent leak from the lower passenger side wheel well around vents toward front.
Is there an auxiliary radiator in there? I see the fins but assumed it was for motor oil or trans fluid. Is the coolant overflow routed to that location? Friggin raining so can’t tear into it tonight and all searches come up empty. I’m obviously not using the correct criteria.
      08-11-2023, 07:05 AM   #2
Johnkwick
Drives: F10 LCI
yes, there's an aux radiator on lower right side of the car. Could be either a hose that goes into the aux, or the aux rad that's leaking
I also have leaking coolant coming from hose that goes into aux rad, but it will leak when pressure in the cooling system starts to decline. I haven't replaced it yet since the rate of coolant loss is low (1x 500ml top up per 3-4 weeks)
View post on imgur.com
This should be the p/n for the hose: 17127619693
aux rad: 17117802662
      08-11-2023, 07:14 AM   #3
jmmdm2
Much appreciated! I’ll tear into it tonight.
