2010 2011 BMW 5 Series Forum F10 F11 550i XDrive Engine Noise, Codes, Etc |
08-26-2023, 12:43 PM | #1 |
Rep 4
Hey All,
Exciting news – I recently managed to snag a 550i at an auction for a deal that was simply too good to pass up (even if i need to replace the engine). This isn't my first BMW, but is my first N63 Now, I find myself in a bit of a troubleshooting puzzle, and I'm turning to this community in the hopes of tapping into your collective wisdom. As a college student, I've taken it upon myself to handle all the necessary work. While I'm prepared for the possibility of an engine rebuild or even a replacement, I'm optimistic that with your guidance, I can explore some other avenues first. The previous owner has definitely done some meddling with fuses, but car appears to be very clean. Here's where I could really use your troubleshooting expertise: Engine Noise: https://drive.google.com/file/d/1kZ1...ew?usp=sharing Misc (Engine Coils/ Spark Plugs/ Injectors/ Vacuum Lines/ Fuel Pump?) P0304 - Cylinder 4 Misfire P0306 - Cylinder 6 Misfire P0171 - System too lean (bank one) IAT or Mass Airflow Sensor? P010D - Mass Airflow “B” Circuit High P0103 - Mass Airflow Circuit High Input P00AD - Intake Air Temperature Sensor 1 Circuit High Bank 2 P0113 - Intake Air Temperature Sensor 1 Circuit High Input O2 Sensor? P0056 - HO2S Heater Control Circuit Bank 2 Sensor 2 P0050 - HO2S Heater Control Circuit (Bank2, Sensor 1) P2419 - Evaporative Emission System Switching Valve Control Circuit Low Misc Electrical Fuses? Only driver door locks with central locking button Driver door does only unlocks with physical key Doors don’t lock Fuel cap lock actuator |
