08-08-2011, 11:31 PM | #1 |
Rep 52
When is TPMS not TPMS?
I've come across many references to the term "..tyres with/without TPMS...".What exactly is this referring to? Is this only applicable to American/Europe BMW F10 (or other BMW models) cars or worldwide?
For the F10...as far as I know....for the Asian Region, especially Malaysia / Singapore /Thailand / Indonesia / Hongkong...the Tyre Pressure Monitoring System (TPMS) is already built-into the system of the car and NOT tyre dependent......but I am ready to stand corrected... For those who know, please enlighten. Thanks |
08-09-2011, 02:20 AM | #3 |
Alpina Addict
Rep 101
Cars without TPM usually have the simpler FTM (Flat Tire Monitoring) system, which relies only on the ABS sensors as measurement source (wheel rotation speed differences). It will issue a warning message on the dash only, no "online" pressure and temperature info.
Current: 2018 Alpina B4 S Coupe AWD
Retired: 2011 Alpina B5 Biturbo, 2007 BMW 650i SMG Coupe |
08-09-2011, 03:36 AM | #4 | |
Rep 3,016
Do you get an actual pressure reading on the screen and do you know how accurate the sensors are? |
08-09-2011, 05:10 AM | #5 |
Alpina Addict
Rep 101
Yep, you're getting the current pressure AND temperature reading for every tire displayed on that semi-transparent 3D cutaway car picture (which is also used i.e. when DDC settings are changed).
And that TPM screen can be assigned to one of the programmable memory buttons. Initially I suspected that one of my sensors might not be reliable, but it turned out that actually the gas station's pressure gauge I've relied on wasn't accurate. No more complaints since my dealership adjusted the pressures using a "decent" gauge.
08-09-2011, 08:30 AM | #6 | |
Rep 52
...Gran Turismo, would you be so kind as to show a pic of how the diagram of pressure and temp looks like on the screen? I think we are being short-changed here in Asia.... |
08-09-2011, 08:58 AM | #7 | |
Rep 285
F10 550i Space Gray | Dinan Stage 5 | Eisenmann Race | ACS springs | 20" Ferric Grey 312 - Michelin PSS
08-09-2011, 10:46 AM | #8 | |
Rep 482
08-09-2011, 12:53 PM | #9 | |
Rep 2,003
So you can see the individual realtime tire pressure+temp on the screen with graphic? wow |
08-09-2011, 02:29 PM | #10 | |
Rep 3,016
08-09-2011, 03:10 PM | #11 |
Rep 111
You're correct. US does not get a readout with actual pressure, just a green okay. Too bad.
08-09-2011, 03:24 PM | #12 |
Alpina Addict
Rep 101
Pic will follow tomorrow, stay tuned
I can't comment on any TPM version not transmitting the readings. On my previous 650i I had the simple ABS based FTM system (German: RPA, Reifen Pannen Anzeige) which would only trigger a warning light (exclamation mark in tire cross-section) + iDrive message in case of a pressure drop. Currently, this FTM is also standard equipment on the German and Swiss F10 versions. The advanced TPM system (German: RDC, Reifen Druck Control) has the BMW option code 2VB here and is fully covered in my BMW owners manual, it's definitely not some Alpina specific feature.
08-09-2011, 03:53 PM | #13 | |
Rep 3,016
Many thanks for all the info; seeing as I'm bordering on OCD with tyre pressures, I'll definitely spec my F12 with this option. |
08-09-2011, 03:59 PM | #14 | |
Rep 1,544
08-09-2011, 04:12 PM | #15 |
Rep 285
Too bad is right. I'd gladly trade my "efficient dynamics" gas mileage meter for tire pressure and coolant temp. anyday
08-10-2011, 08:42 AM | #16 | |
Rep 111
Wonder if the wheel sensors are different in US vs other markets. Then maybe it's a coding issue that might with some insight give us actual pressure information? Anyone researched it?? |
08-10-2011, 02:10 PM | #17 |
Alpina Addict
Rep 101
Ok, here's the promised (crappy iPhone) pic of the TPM in action:
08-10-2011, 02:36 PM | #18 |
Rep 3,016
GT, thanks very much for taking the trouble to post the picture - this looks really good and exactly what I hoped it would be. For £250 I shall definitely be choosing this option on my F12 next year.
08-10-2011, 11:26 PM | #19 |
Rep 2,003
Awesome .. just as one would have imagined it! But this would make you want to not target to the 0.05bar to avoid getting uneven readings on four corners or if one side of your garage gets more heating than the other you're screwed. Checking it could easily develop into a bad habit. Last edited by grimlock; 08-10-2011 at 11:36 PM.. |
08-11-2011, 07:43 AM | #20 |
Rep 206
08-11-2011, 07:56 AM | #21 |
Rep 111
That's perfect, temperature and pressure. Wish we could get it.
Seems BMW thinks the US market can only understand color coded simplistic information. Feels like in this market they're really promoting luxo appliances and not driving machines. Then again it is the case with the vast majority of owners who want it simple. iiwii |
08-14-2011, 02:02 AM | #22 | ||
Rep 52
Would you know if the car's system needs to be coded to receive TPMS signal info or is it "plug and play"? Am considering buying the TPMS sensors to fit on my tyres.... Quote:
