2010 2011 BMW 5 Series Forum F10 JB4 headlight malfunction |
05-20-2017, 01:03 PM | #1 |
Rep 26
Hello All,
Just got a JB4 stage 2 install on my 2011 550xi and it is throwing up a headlight, turn signal and a few other issues Any idea how to solve? |
05-20-2017, 02:44 PM | #3 | |
Rep 26
When disabled the malfunction clears. |
05-20-2017, 04:18 PM | #5 | |
Rep 26
Any idea how to get rid of the drive train malfunction? Been reading up but some of the explanations are Chinese to me lol |
05-21-2017, 12:30 AM | #6 |
Dream crusher
984
Rep 2,421
Doesn't the JB4 auto clear codes? If not go to autozone and have them clear the codes or get the icarly app and the adaptor.
If the drivetrain malfunction is still happening I don't think that person who installed it was a "professional"
IG: @bmwdoubles |
05-21-2017, 08:14 AM | #7 | |
Rep 26
Been doing some research and it is suggested to clean the MAF sensor. |
05-21-2017, 10:19 AM | #8 | ||
Dream crusher
984
Rep 2,421
Also a badly wired JB4 that is giving those kinds of errors is an opportunity installation problem. I would pull it if the problem is indecipherable until its properly hooked up. You wouldn't want additional electrical problems due to a bad install.
IG: @bmwdoubles |
FSociety3812.50 |
05-22-2017, 02:03 AM | #9 |
Rep 785
I don't think he has JB4, his original post says Stage 2 which isn't JB4 and doesn't have CANbus access. So he has to manually clear the code, I don't think they wired your tune correctly. If you're DTM comes on right when turning the vehicle on, it's not installed properly or the tune is faulty. If the tune isn't installed properly, I hope they numbered the wires or else you'll need to take the vehicle to BMW or pull up the wiring diagram yourself with ISTA and make sure the wires go back to the right pins.
05-22-2017, 04:28 PM | #11 |
Dream crusher
984
Rep 2,421
Bummer, the installer should be responsible. Why would they accept a job they weren't capable of without disclosing the risk?
IG: @bmwdoubles |
FSociety3812.50 |
05-23-2017, 10:03 AM | #14 |
Dream crusher
984
Rep 2,421
That's a good point. Max install time is one hour and that's if you've never done it before.
IG: @bmwdoubles |
05-23-2017, 03:52 PM | #15 | |
Rep 26
400 in and 400 out. So 800... Called it 1000 for simplicity. |
05-23-2017, 04:00 PM | #16 |
Rep 317
05-23-2017, 04:07 PM | #17 |
Joint Chiefs of Staff
4916
Rep 115,980
What a headache. With the old Stage2 if you install the TMAP connectors only and NEVER touch the DME wires (just tuck them out of the way) it still works like Stage1.
Mike |
05-23-2017, 06:09 PM | #18 |
Dream crusher
984
Rep 2,421
Did they give you an invoice for the work? Have another shop estimate the install time and then take them to small claims. That's no joke robbery.
IG: @bmwdoubles |
05-23-2017, 10:46 PM | #19 |
Rep 2,416
WOW YOU GOT RIPPED OFF!!! small claims court 100% this is at maximum a $200 job from someone who has done it many times.
2011 550i RWD 60-130 7.35
