05-17-2014, 08:15 AM | #1 |
nhanweezy
21
Rep 436
19x11 +12 offset
http://www.m3post.com/forums/showthread.php?t=980484
Will this work on the rear? What tires will I need to fit our F10s? |
05-19-2014, 11:20 AM | #3 |
nhanweezy
21
Rep 436
05-20-2014, 03:42 PM | #5 |
Rep 25,989
Definitely will not work on the F10.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
05-25-2014, 05:04 AM | #7 |
Rep 29,202
05-26-2014, 04:36 AM | #9 |
Rep 29,202
Did you test drive it too?
05-26-2014, 08:33 AM | #10 |
Rep 50
05-26-2014, 02:18 PM | #11 |
Sunburned
238
Rep 1,097
Drives: '16 F83 M4 Convertible 6MT
no way they would clear
i have 20x10.5 +27 and when i had 285s they destroyed my fenders
2016 M4 Convertible 6MT - SO/SO
2013 535i 6MT MSport - Retired 2011 Z4 SDrive35i 6MT- Retired |
05-26-2014, 05:05 PM | #12 |
Rep 50
05-27-2014, 02:00 AM | #13 |
Rep 1,247
Drives: 2022 Taycan GTS, 2018 M4, 2016
if you want to go for x11, offset needs to be 34mm
according to many wheels for sale F10 members 20x10.5 +40mm is good according to Forgestar 20x10.5 +35mm for most you can go out calculate 20x10.5 +40mm to 20x11 +34mm Inner Clearance = same Outer Position = EXTEND an extra 12mm calculate 20x10.5 +40mm to 20x10.5 +27mm Inner Clearance = 13mm MORE Outer Position = EXTEND an extra 13mm |
05-27-2014, 04:39 AM | #14 | |
Rep 29,202
BTW, my 20x11 are ET46.
Hphan09274.50 |
05-27-2014, 04:15 PM | #15 | |
Rep 1,247
Thank you for your info i don't have enough data to know how inside we can go for, the most inside offset i see is 10.5 +40. that is why i did not change the inner clearance but increase outer position. if your 11 +46 does not have problem on rear, than it is the best offset for 11" that is for sure and i can use your data to calculate. also could you share your front offset please. right now the data i have is only from +25 to +28 for 9" thanks |
05-27-2014, 06:06 PM | #16 | |
Rep 29,202
My front offset is ET26.
05-28-2014, 06:46 PM | #17 |
Rep 1,247
