2010 2011 BMW 5 Series Forum F10 ///M Suspensions for 535i |
10-11-2016, 02:45 AM | #1 |
Rep 98
Drives: F10 535i M Sport - e31 850csi
Hello all,
I noticed that stock F10's have not all the same height, I know that the xdrive ones are more higher than the others. And I know that the ones which have the M Suspensions are 10mm lower than the "normal" ones. So I've a question, the difference between the M Suspension and the normal suspension is only the short springs ? Or the shocks are also different ? And what do you think about replacing only the springs by custom springs (-15mm on the front and -10mm on the rear) on stock shocks ? Thanks ! |
10-12-2016, 07:37 AM | #3 |
Rep 98
ok thanks,
If I set custom springs (-15mm) on stock shocks without changing my shocks it will be fine ? My shocks will not be out of service after 30000km ? |
10-27-2016, 04:37 AM | #4 |
Rep 98
I did some research on the net and I sent an email to Sachs.de (which is the OEM shock abosrbers supplier for BMW)
They sent me a PDF with all references of shocks. And.... the shocks are the same for a Standard or a M suspension You can see that in this picture (ST means Standard suspensions and MT means M Suspensions) Moreover, according to that and what you see on realoem.com, the ones difference between the M Suspensions and the standard are : - Coils - Front Stabilizer with bushing - Rear stabilizer with bushing For the coils, what I find : So to install a M chassis on the F10, you need only coils, and stabilizers with corresponding bushings. |
10-27-2016, 02:18 PM | #5 |
Rep 878
^ Doesn't M-Sport have EDC? My BMW technician seems to think so. I have the option to go Sport+ and there is a noticeable difference in handling response when activated.
-WJV
10-27-2016, 02:22 PM | #6 |
Rep 98
12-09-2016, 06:24 AM | #8 |
krrrraaauuuuut
177
Rep 524
"M Sport" suspension is the option 704, not the "M" suspension you would get on an M5.
(Current) G12 750i X Drive / M-Sport / LOADED
(Current) 997 Turbo / 6MT / HRE FF01, Land Rover LR3 - Overlanding Family Adventure Shed, E60 525i - "family beater", Alfa Romeo Spyder Veloce - garage art (Gone) F10 550i / M-Sport, D2 Audi S8, AP1 S2000, Z32 300zx, S13 240sx |
