2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Curb weight of 550i?
      11-11-2013, 08:40 PM   #1
silvercreek
Drives: 535i
Smile Curb weight of 550i?
Hi all,
Not sure why it's hard for me to find this, but I'm trying to find the curb weight of a 2014 535i vs 550i. Does anyone know what the weights are? Trying to see if the extra 145hp is worth the added weight (but can't seem to find what that is).
Speaking of that, anyone have a list of weights for each of the options?
      11-12-2013, 07:32 AM   #2
kube
Drives: 2014 535d xDrive MSport
Originally Posted by bomax View Post
Hi all,
Listed under the "Specifications" tab for the 550 on the bmwusa.com website. Amazing what's out there is you just look
http://www.bmwusa.com/Standard/Conte...fications.aspx
Current: 2014 BMW 535d xDrive MSport | Dark Graphite | Black l Dark Wood | Loaded
Current: 2018 BMW X3 30i | 2014 MINI Cooper S | 2007 VW Jetta 2.5
Retired: 2015 X3 28i | 2011 BMW 535i xDrive MSport | 2008 BMW 535ix | 2005 BMW X5 4.4i | 2002 BMW X5 4.4i | 1986 BMW 325e (275k miles) | 1983 BMW 320i
      11-12-2013, 10:41 AM   #3
Grover432
Drives: 2013 535 XDrive
You might want to check the "standard equipment" list for the 550i as compared to the 535i. The 145 hp might be hauling around some extra equipment that is standard on the 550.
2013 535 X Drive, Alpine White/M Sport/Executive/Apps/Black Dakota/Fineline Anthracite
      11-12-2013, 11:44 AM   #4
numbersguy
Drives: 2013 535i
You might want to take a look yourself. Curb weights were listed for last year's cars but many of the newer models list only gross vehicle weight.
      11-12-2013, 01:00 PM   #5
raleedy
Drives: 2016 228i 6-speed
So compare those. The owner's manual (available on line from BMWUSA.COM) has gross weight and allowable load figures for all models, together with fluid capacities, so it should be relatively easy to calculate curb weight and make the comparisons you want. The weight difference looks to me to be roughly 200 lb.
      11-12-2013, 02:09 PM   #6
Richard Cranium
Drives: It's a truck
Hi all,
Rest Assured the weight isn't 50% more than the 535 making the roughly 50% more power definitely worth it.
      11-12-2013, 02:11 PM   #7
Grover432
I think you are safe to use last years curb weights.
      11-12-2013, 04:01 PM   #8
raleedy
I would have thought so as well, but there is a significant reduction in load capacity from 2013 to 2014 -- I have no idea why, or whether curb weight is affected at all.
Incidentally, I think one reason curb weight is no longer specified is that it doesn't seem to have a precise standard. It isn't clear, for example, whether a full tank of fuel is included: something that in these cars accounts for as much as 150 lb.
      11-13-2013, 06:53 AM   #9
Grover432
If it was a pickup truck, I'd be concerned about capacity. If you want to go faster, get the 550.
      11-13-2013, 08:32 AM   #10
raleedy
At least in the U.S. (not sure about Canada), I think no one gives a hoot about rated load capacity. They carry what they carry. But can one infer from reduced load capacity an increase in net (unladen) weight? Or maybe just a change in tires?
As for speed, it's my impression that all the F10 models are similarly limited.
      11-13-2013, 08:43 AM   #11
alpinef10
Drives: BMW 550xi M sport
Could be the use of the new 3rd generation rfts which can go for 30 miles instead of 50 like the 2nd gen which means a softer sidewall therefore lower load capacity perhaps
      11-13-2013, 10:07 AM   #12
Grover432
Its never been about top speed in North America, but how quickly you can get there.
      11-13-2013, 06:18 PM   #13
newtoav
Drives: 2014 535i | 2013 X3 2.8 |
Has anyone noticed that the weights for all 5 Series on the BMW USA website are wrong? It seems to me they are showing X5 weights, but regardless, I sure am glad the lardy F10 doesn't quite weigh 5,100 lbs +
The weight for the 550i is, per the German BMW website, 1905 kg or 4199 lbs.
Look at that, I just made your car 1,200 lbs ligther!
1997 328is (retired)
2006 330i (retired)
2011 X5 35d (retired)
2013 X3 28
2014 535i
      11-13-2013, 06:51 PM   #14
raleedy
These are gross weights now -- maximum permissible load including passengers, cargo and fluids. Not of much use to Americans, who as a rule pay no attention to load limits. BMW used to give curb weight, but has abandoned that for some reason -- maybe because it isn't very well defined.
      11-13-2013, 07:19 PM   #15
xs2man
xs2man's Avatar
18
Drives: 2013 F11 530d M-Sport
To the Op.
Small difference in weight vs large difference is power???
Didn't think this question needed asked to be honest. But I'll answer it.
Yes. It's worth it.
530d M-Sport Touring.
      11-13-2013, 07:53 PM   #16
newtoav
@raleedy - I really think it's an editorial error. I mean, the website is far from perfect. Just to make my point, if they started listing gross weights - they would do it across all models, no?
Here are the weights of other models - they are all much lower. Also the max allowed weight as per the German website is 5357 lbs, again, it doesn't add up. Again, I just feel much better knowing my 335 is 3800 odd lbs, and not 5200...
2006 330i (retired)
2013 X3 28
2014 535i
      11-13-2013, 09:57 PM   #17
Grover432
When you look at the 2013 owners manual, the Gross Approved Weight is 5,401 and the max load is 1,036 so I calculate the curb weight to be 5,401 - 1,036 = 4,365 lbs (give or take) for a 2013 model. I doubt the 2014 is materially different. If the owners manual us wrong, the label in located in the door frame will have the correct gross and max load information.
      11-13-2013, 10:13 PM   #18
raleedy
Grover432 has this right. The US website is in the process of switching from unladen weights to gross weights in the specifications. These are clearly different measures. There is no particular reason to expect the European and Canadian and US specs to be exactly the same. It's also necessary to account for the sudden drop of nearly 200 lbs in maximum load from 2013 to 2014 in the U.S. spec.
      11-14-2013, 10:44 AM   #19
newtoav
You guys are absolutely right. I was mistaken. I checked the 5er manuals, and they do reflect gross weights. Same for other models (although the website doesn't yet).
The only reason I can think of is to show a GVWR of > 6000 for the X5 so it qualifies for section 179 accelerated depreciation. Although there must be better reasons too.
Thanks for educating me on this matter. Your wisdom - and the wisdom of the group - is much appreciated.
2006 330i (retired)
2013 X3 28
2014 535i
      11-14-2013, 03:04 PM   #20
raleedy
I think we all learned something here. I suspect BMW is moving to gross vehicle weight because it is a stronger standard. Curb weight means different things to different people.
I'm intrigued by the substantial drop in gross weight, which appears to come from a reduction in the maximum load. I'd like to know more about that.
      11-14-2013, 03:53 PM   #21
silvercreek
Drives: 535i
Thanks all. Glad I wasn't the only one confused by this situation. I think the 550 weighs in at 4199lbs (per newtoav and the German site). Hefty for sure, but not totally outrageous.
      11-14-2013, 05:34 PM   #22
1HOT BMR
1HOT BMR's Avatar
Drives: Car-less and shopping +'12 35d
550i = 4,365 lbs
535i = 4,090 lbs
