2010 2011 BMW 5 Series Forum F10 BMW Automatic Transmission Shifter |
04-19-2011, 11:09 AM | #1 |
Rep 33
Does anyone know BMW's motive to switch to the new proprietary shifters as opposed to the traditional sliding shifters found in almost every other car? Anyone know the advantages it provides?
04-19-2011, 11:25 AM | #3 |
Rep 519
Most likely because the new Eight Speed Tranny is totally electronic and no longer requires a direct linkage. Therefore likely less costly in parts and cheaper to do. The only downside is that it gets some getting used to over a gated type shifter....and we can no longer put the car in Neutral without having to start the car! (sometimes to get my old E39 out of the garage, I just used to get in...put it in neutral and could just roll it out) Can't do that anymore.
04-19-2011, 01:18 PM | #4 |
Rep 6,694
Clears up massive center console room not having to account for a shifter that moves. Just look at what the F10 center console becomes with the manual shifter.
04-19-2011, 08:00 PM | #5 | |
Sixties Drag Racer
37
Rep 409
just getting us ready
Look at it this way, they are just getting us ready and use to a joystick for when they remove the steering wheel. Think about it. Move the stick left and the car goes left. move it right and so on. move it forward and the car accelerates. Pull bank and it stops. Like I said, "they are just getting us ready" Just my 2 cents
Mspeasl - Central Illinois - USA :
My Garage: 2011 - Cashmere Silver Metallic BMW, 528i (Delivered 17 January 2011) 2008 - Radiant Red Toyota, M6 'X-Runner' (Delivered 15 November 2007) 1957 - Chevrolet Bel Air 2dr Coupe' Drag Car (2nd Owner since 1964) 1947 - Chevrolet Sport Master Coupe' Street Rod (2nd Owner since 1974) |
04-20-2011, 06:33 AM | #6 |
Rep 3,016
Not to mention the inability to move the car in the event of an engine failure.
04-21-2011, 07:47 AM | #7 |
Rep 46
No idea. Looks cool, but that is why my wife does not like to drive the car. We used to swap the cars every time we needed, and now she refuses to do that. The same applies to turn signal lever.
04-21-2011, 08:43 AM | #8 |
Rep 3,016
04-21-2011, 01:26 PM | #9 | |
Rep 108
She loves it more than the old E61. I had to hand her some help, but that was for not longer then the first two weeks of owning the car. Now after four months and ten thousand miles a lot of times my beloved F11 is not at the parking and the taken by her. And I have to drive the sullen VW Golf GTI to work...... |
04-21-2011, 02:04 PM | #10 |
Rep 6,694
04-21-2011, 03:20 PM | #11 | |
Rep 776
Isn't this a good thing? i Know I get nervous when my wife drives my car. |
04-21-2011, 03:25 PM | #12 |
Rep 3,016
04-21-2011, 03:42 PM | #13 |
Rep 46
04-21-2011, 06:29 PM | #15 |
Rep 6,694
Errr, no. Not unless you've only been driving BMW's, as others have said. Most cars have turn signal levers that, you know, stay down or up until the signal turns off? In just about any car made since, uh, about 1940.
04-22-2011, 05:39 AM | #17 | ||
Rep 3,016
As it happens the Vauxhall Vectra, to name but one that springs to mind, has the same type of non-latching turn signal lever and, from admittedly dubious memory, I'm pretty sure it was likewise in my old 2001 Audi. However, I could certainly be wrong there and I'll gladly admit it rather than cause any offence or angst amongst my fellow forum users |
04-26-2011, 01:45 PM | #19 |
Rep 46
Another question: I was playing with this in a car while waiting for kids. I noticed, that in fact it has 5 positions. Neutral (middle) and 2 up (R) and 2 down (D). Is there any difference when you switch to D for example if you push it gently to the first position down, or to the end? I could not find any.
04-26-2011, 02:14 PM | #20 | |
Rep 6,694
Yeah, I couldn't figure out why that was myself. Noticed no difference. |
04-26-2011, 03:12 PM | #21 |
Rep 28
Drives: F10 525d
If the car is in reverse (R):
Gentle push backwards: Puts the car in neutral (N) Long push backwards: Puts the car directly in drive (D) |
04-26-2011, 11:24 PM | #22 |
Rep 1,684
This design is called "stateless.". This allows you to turn off the engine and have it fall into park with no movement of the auto shifter.
Same goes for the turn signal. It is stateless too. Now, fwd and reverse gears resolve easily (the shifter goes to park if u open the door at the right time). However, the stateless design failed to work if you left the shifter in sport mode and then turn the engine off. The fix for this required an automated movement of the shifter to park to get back to its stateless state! Go ahead and try it. Power on the engine, shift to sport mode then power off the engine. You will see BMW had to override the logic here by physically moving the stick from sport to park. Almost all of the buttons are stateless. This allows the electronics to reset to on or off without having to manipulate the button into a physical position. Except, of course, the sport mode to park described above. Or manual mode to park for that matter since there is no physical difference between sport and manual as far as the shifter is concerned as it stateless. Compare to a light switch in your house that has an on state and an off state. |
