2010 2011 BMW 5 Series Forum F10 Anyone else track their 5 series |
05-31-2018, 07:38 PM | #1 |
Rep 150
Just starting out myself:
During a previous event I had complete brake failure where the pedal fell to the floor so I got steel braided brake lines, EBC yellow track pads, and Motul 660 fluid, which appears to have remedied the issue but I didn't abuse the brakes quite as hard at this event to test the limits. Anyone have a similar experience? |
05-31-2018, 08:19 PM | #2 | |
Rep 343
05-31-2018, 08:43 PM | #3 | |
Rep 150
The weight undoubtedly holds it back in the competitive space but it doesn't stop it from being a fun car to drive :P In terms of other mods I've done: - clutch delay valve delete - sprint booster throttle by wire override - makes the throttle way more responsive I'm currently just going for driver feel so this is probably fine for now but I'd be curious what others have done. |
SC300T26.00 |
05-31-2018, 10:07 PM | #4 | |
Rep 343
- sway bars front & rear (this is a must for our F10's) - Bilstein B12 kit. for RWD F10's only. great suspension that comes in one "out of the box" setting. The eibach springs don't offer a major drop, and overall this kit helps strike a perfect balance between street comfort and performance while still performing well on the track. - Camber plates. the camber setup is pretty mild on the F10, which causes understeer. this isnt such a big issue because our double wishbone suspension automatically increases negative camber to the outside wheel when cornering, but some extra negative camber would sure help the car feel more balanced and negate some of the understeer. the only option I see is Dinan, which does not sacrifice ride comfort like your typical camber plate. offers 0.6 degrees of adjustability. - Meyle upper control arms: further helps tune your negative camber. addition -0.3 of adjustment. - rear strut mounts and bushings: helps give the car a more planted feel when cornering. apparently these are a must for the F10 chassis, and any BMW really for that matter. - some lightweight aftermarket forged rims with non runflat tires. OEM BMW rims are very, very heavy. this is because of the runflat tires they are designed to run on. if you do get non runflat tires (which I recommend, because they make the ride far smoother and help with performance) I would suggest getting an alignment to help optimize for the new tires. your current alignment is designed to work best with runflat tires. - LSD: for RWD models only. highly recommended modification. helps oversteer feel more controllable and smoother. open differentials are designed to send more power to the wheel with less grip, which is good for safety reasons (if you even consider understeer a safety feature) while a LSD sends power to the tire with the most grip. contrary to what many believe, an LSD will not induce MORE oversteer VS. an open diff counterpart, however. That's about it as far as handling mods go. power-wise, I'd go for a downpipe and ECU tune. an intercooler is a must for turbo BMW's as the stock ones are shit, then a charge-pipe, and that's about it. I doubt much is needed for your twin turbo V8... |
06-01-2018, 09:21 AM | #5 |
Rep 4,209
I've debated going to the local racetrack here (pacific raceways) but I'm too worried about breaking something on my car or getting into an accident. Maybe the next car.
SC300T26.00 |
06-01-2018, 04:39 PM | #6 |
Rep 6,310
Cheap Miata or Honda S2000 is all you need. Been in one around a track with a good driver. Then took my old Z4 Coupe, and the new Z4 E89 3l turbo one. Gotta say S2000 was the most fun. After the track, he topped up the oil and went back home. 100km away from track. Thats the kinda shit these little cars do. Drive to track, race, go home. My friends Z4 went into limp mode twice, mine had developed a small crack in an exhaust... Im just saying.
F30.F11.E86.E90.E90.E36 |
06-01-2018, 11:54 PM | #7 | |
Rep 343
you can thank the ridiculous temperatures these motors fitted with electric water-pumps run at. if you had a vented hood and maybe some thicker oil, that should be enough to keep the temps reasonable. |
06-02-2018, 04:15 AM | #8 |
Rep 6,310
Pretty sure it was old and rusted and from stress in some area it burned through or smth. My car was low miles, that stood a lot with previous owner and when I bought it the undercarriage had some rust spots, bits under hood were eaten by some animal, etc. Took a bit of tinkering to bring it to shape but low miles and good price was tempting (plus excellent color combo). But it was rusting quite a bit when I sold it, you cant really stop that stuff once it starts going i guess.
06-02-2018, 09:45 PM | #9 |
Rep 115
Drives: 2011 535i (6sp)
Nice to see an F10 on the track! Your driving looked smooth and deliberate! Good combination of traits!
I would imagine the stock brake setup/especially fluid would be highly taxed on this nearly 5k lb car. Good to know a decent combo of pad/fluid/line to start with. I read that you removed your CDV, did the lines simply plug into each other once removed? Haven't yet done it on my F10 535. It did on my old E90 and E46. To 'Big Mexican Women,' you mention an LSD. What manufacturer is making the 535i one? |
06-02-2018, 11:28 PM | #10 | |
Rep 343
06-03-2018, 12:05 AM | #11 |
Rep 115
This may be our only option:
http://diffsonline.com/bmw-f10-535i-...l#.WxNi2BZlDYU It seems wavetrac makes one for the 550i |
Big Mexican Women101.50 |
06-04-2018, 02:51 PM | #12 | |
Rep 866
06-04-2018, 03:29 PM | #13 |
Rep 115
Sorry, Clutch Delay Valve ("CDV"). The theory is that there is a small connector valve at which point hydraulic fluid is somewhat restricted, effectively slowing down the actual clutch action in order to avoid potential damage. For anyone who has driven manuals, you'll have to adjust your shifting style to compensate.
06-04-2018, 04:23 PM | #14 |
krrrraaauuuuut
177
Rep 524
back in the day... there were a bunch of guys on Audiworld that tracked their D2 S8 / A8s... brake upgrades were a must but I think the cars handled the track well. I used to have a S2000... that was a different track animal, but I think there's a place for all sizes of cars... makes you learn the limits of the car you're driving for sure.
(Current) G12 750i X Drive / M-Sport / LOADED
(Current) 997 Turbo / 6MT / HRE FF01, Land Rover LR3 - Overlanding Family Adventure Shed, E60 525i - "family beater", Alfa Romeo Spyder Veloce - garage art (Gone) F10 550i / M-Sport, D2 Audi S8, AP1 S2000, Z32 300zx, S13 240sx |
06-08-2018, 09:18 AM | #15 |
Rep 116
Why are we discouraging tracking an F10? Anything that pushes the limits of the car moves the platform forward. Anyone can see that the F10 isn't the best starting place due to weight and mushy calibration, but there are far worse options... The F10 has a balanced chassis, the hard points of the suspension are well thought out, they put the power down well out of turns, and have a decent(ish) power to weight ratio. It doesn't matter how fast you go on the track, there is always going to be someone faster. I see it more as an enthusiast getting to drive at a level not possible on the street.
whinojosa21.00 |
06-08-2018, 09:53 AM | #16 | |
Rep 343
