2010 2011 BMW 5 Series Forum F10 Drivetrain malfunction... Limp mode. How many things could this be? |
02-22-2017, 05:42 PM | #1 |
Rep 81
2012 535i 6MT with ~70K miles and I am getting the drivetrain malfunction error and the car goes in limp mode. I know this could represent TONS of problems and only by looking at the specific codes could one know with certainty, but I'd like to add a few things and maybe someone who really knows this stuff could narrow the issue down to a handful of conditions. I'd also like to know what it would take ($) to correct those conditions if that's something you can guess too.
(A) This has been happening for the past 10K+ miles. (B) This happens ALWAYS when I start my card cold and I push it just a little bit, like almost nothing. The engine stutters and I get the error and limp mode. (C) Once the car is hot, this rarely happens, although if I really push it on the highway, it will. It does take a bit of abuse, however. Not much, mind you, but this is definitely more of a cold start problem. (D) No matter when or why this happens, turning the ignition off and back on right away ALWAYS corrects the problem. (E) Most times, what happens is the error appears on my screen and the car goes in limp mode and continues this way for as long as I'm driving or even idling, until I stop. Now, this is rare (happened only 3-4 times during these 10K miles), but I've also had the error and chime come on and the car go in limp mode and then, the error continues coming up every few seconds (the car never leaves limp mode), which gets very annoying with the chime... until I stop and start again. (F) When the car is cold, starting always takes the crank a few cycles. I don't even know if I said that correctly, but the point is that when I first start the car in the mornings, I turn the ignition and the car cranks for about 5 seconds before it starts. This never happens when the car is hot. (G) The car idles and rides a little rough, but the spark plugs are relatively new. Feel free to ask anything else you can think of, but does this give you any indication of what could be wrong with my car? I do ultimately plan on taking the car to a BMW shop. I just wanted to see if I could have some preliminary ideas that I can suggest to the mechanics. Thank you in advance!
Current: 2012 535i M Sport 6MT + 2019 Volvo XC60 T8 Inscription (PHEV)
Past: 2011 BMW X3 xDrive35i, 2008 BMW 535i 6MT, 2009 BMW 335i sedan 6MT, 2007 BMW 335i sedan 6MT, 2007 Volvo S80 V8 Sport AT, 2005 Volvo S60R 6MT, 2001 Audi S4 6MT, 1998 Volkswagen GTI VR6 6MT |
02-22-2017, 08:07 PM | #2 |
Rep 1,287
If you haven't already, I recommend buying a bottle of BMW fuel system cleaner Plus by Techron. I have been using it in between oil changes and no longer experience drive train malfunction errors and my car has been idling much better during cold starts. You can buy either the BMW branded ones or the Techron branded ones as they are both the same concentrate.
02-23-2017, 05:56 PM | #4 | |
Rep 81
This could definitely be it. I really need to take the car into a BMW shop, no way around that. This is happening to me multiple times daily.
02-23-2017, 06:09 PM | #5 | ||
Rep 1,287
02-23-2017, 07:45 PM | #6 |
Rep 1,254
I had same thing happened to me twice I think I had fuel injector misfiring
When this happened to me I did research make sure you filing top quality fuel in your car and some people say keeping your car in sport mode helps. Good luck
The_Transporter204.00 |
02-24-2017, 10:56 AM | #7 |
Rep 491
Any idea why sport mode helps? My 550 hasn't gone into limp mode but 3 times over the last 30k miles but it did rough idle before the injectors got swapped and now it may be coming back slowly or I'm being paranoid lol.
02-24-2017, 04:13 PM | #8 | |
Rep 1,254
you will experience rough idle regardless of the car I think people just have higher expectations when it comes to BMW but it will happened regardless what kind of car you drive
02-24-2017, 05:06 PM | #9 |
Rep 81
I only use 93 octane Shell or Chevron and my car never leaves Sport or Sport+ modes.
02-25-2017, 08:18 AM | #10 |
Rep 1,254
I hear that, for most part I do same thing unless wife and kids are with me.
02-26-2017, 09:52 AM | #11 |
Rep 33
09-08-2019, 08:58 PM | #13 |
Rep 1
I started having this issue at 92k in my 3 series after long-distance driving and got codes for a high-pressure fuel pump. Took it to a shop and confirmed my findings. Got it replaced and everything ran smoothly even when running it hard in sport mode.
5k miles later after another road trip the same thing happened with the driver malfunction error but this time i lost full power. restated the car and everything was normal. I wonder if the fuel pump is going out again or if it could be fuel injectors, spark plugs, etc. has anyone gotten codes after this has happened? |
09-09-2019, 07:22 PM | #14 | |
Rep 14,522
09-17-2019, 06:27 AM | #15 |
Rep 8
I am having drivetrain malfunction issues on my 2013 528i xdrive.
The codes I am getting are:11A002, 11AC02, 213601, 108A01, P0015, and P0087. The car has a brand new engine, turbo, air filter, tmap, fuel pressure sensor, lpfp, hpfp, spark plugs, and coils. I have also cleaned the MAF. I am lost on what to do next. Please... Please... provide assistance on next steps to take. Thanks in advanced. |
01-22-2022, 10:55 AM | #18 |
Rep 19
Having the same issue with my 2013 X3 28i
Always when cold, or if I switch to sport on the highway and push her I get the malfunction. Brought it to the Bmw center and they came back with “stumped “they told me they have no clue what’s wrong with my car I was furious picked up my vehicle and decided to go to AutoZone and picked up the fuel injector cleaner so that’s where I am now… Going to see if that works… Any new updates from anyone experiencing the same here? |
01-28-2022, 08:37 PM | #19 |
Rep 4
Same boat for me and my 2012 528xi with 85k miles on it. My mechanic confirmed I would need a new engine along with other items totaling to slightly over $10k RIP to my F10 as of December 23rd. Now in the process of awaiting delivery of my G30.
