2010 2011 BMW 5 Series Forum F10 Seatbelt Buckles Installed Incorrectly |
06-25-2015, 06:21 PM | #1 |
Rep 2,246
Having had numerous loaners, why are some seatbelt buckles installed incorrectly, where the top of the buckle is facing the b-pillar and not the seat as it should so the belt can lay flat across the occupant. When facing the b-pillar it instead it lays twisted. Could be a problem in an accident, as the twisted belt could cut into and injure, instead of properly dispersing pressure.
I often find myself adjusting incorrectly installed buckles, which is not easy. |
06-25-2015, 11:38 PM | #3 |
Rep 2,246
Hmm; not easy to do what I'm referring to, and not something someone would twist for preference. Also, this is on nearly new loaners, so it's a variance from the factory. What must be done to fix is bunch the belt in the center of the buckle - where there is an slightly enlarged cut out - and flip, but not easily done...
06-26-2015, 06:58 AM | #5 |
Rep 15,858
Interesting...
My sister runs a VW Caravelle (7-seater) and it is used by many different passengers. I assure you the seatbelt buckles were all correct from the factory, but not uncommon to have to 'turn a buckle'. It takes quite a bit of effort to do, so how do users get them to simply turn when using the belts? They obviously can turn with use, but what action does it, baffles me. HighlandPete |
06-26-2015, 09:44 AM | #6 | |
Rep 2,246
Attached is a picture of what I'm referring to. To turn / flip the buckle, so the belt isn't twisted, you have to bunch the belt up in the area circled and flip. Not easy! :| |
06-26-2015, 02:33 PM | #8 | |
Rep 10,185
Quite a struggle to get them back correct sometimes though, but possible
BMW if you are reading, I need a job, Please. |
06-26-2015, 03:28 PM | #10 | |
Rep 15,858
Google "twisted seat belt buckles", it's a common problem, there is even a video on how to put them back the correct way around. One page even mentions the idea that users believe the manufacturers fit them the wrong way around! HighlandPete PS: A how to fix.... http://cockeyed.com/lessons/seatbelt/seatbelt.html |
06-28-2015, 03:14 PM | #12 |
Rep 139
Ironically I jumped into my brother's M5 yesterday and lo and behold.. twisted seat belt I kid you not!
NO his kids do not sit in the front of the car. I sat thinking of this thread and chuckling |
