2010 2011 BMW 5 Series Forum F10 Alignment recommendations |
03-20-2017, 08:20 AM | #1 |
Rep 76
Is this recommended? Should I do alignment for this?
It's pulling slightly to the right right now. Will alignment fix the issue of pulling right? Thanks.
I am new here. Thank you for your help!!!
03-20-2017, 10:07 AM | #2 |
Rep 14,522
so couldn't the alignment shop tell you they could correct this? or is this all they can do?
03-20-2017, 10:11 AM | #3 |
Rep 76
They said they will do the alignment,but does not promise pulling will be fixed after.
trinious25110.00 |
03-20-2017, 10:20 AM | #4 |
Rep 15,858
A lot of errors, but the readout doesn't really give enough detail to know if the poor alignment is the direct cause of any pull.
Need to know how both the front and rear toe settings are shared across the car, and the thrust angle/thrust line on the present settings. Needs the geometry recalibrated anyway, pull or no pull. |
03-20-2017, 10:24 AM | #5 | |
Rep 76
03-20-2017, 02:39 PM | #6 |
Rep 137
the way the toe is set up right now, it will pull to the right if you let go of the steering wheel. at least that's what i see. i know toe is adjustable but idk about the rear camber though.
03-20-2017, 04:41 PM | #7 |
Rep 76
I got my car back. Still pulling to the right. I have a new data sheet. Please help!
03-20-2017, 04:54 PM | #8 | |
Rep 76
https://m.imgur.com/gallery/HtIot
03-20-2017, 06:43 PM | #9 |
Rep 1,214
F10's are known for having an issue pulling to the right. It can be corrected with a software update to the EPS system, and or by preloading the struts.
Your alignment still isn't what I'd want to see leaving the shop, but its not awful or anything. These things said your tires can also create a pull if they are worn irregularly. |
03-20-2017, 08:35 PM | #10 |
Rep 14,522
Yup! Once the tires have improper wear on them even after an alignment it may still pull. Try rotating the tires and see if that helps
03-20-2017, 08:42 PM | #11 | |
Rep 76
Thanks
03-20-2017, 08:43 PM | #12 | |
Rep 76
03-20-2017, 09:02 PM | #13 |
Rep 1,214
I appreciate your enthusiasm, but that tire wear print out is completely worthless when it comes to actually evaluating the subjective irregularities between tires.
Furthermore these are all things your shop should already be doing for you. Is this a BMW specialist and or dealer, or some generic shop? I'll take it its the latter as any shop worth its salt would have corrected this long before you got anywhere near a message board with these questions. |
03-20-2017, 09:09 PM | #14 | |
Rep 76
03-21-2017, 07:53 AM | #15 |
Rep 1,214
BMW has a SIB out on programming the EPS to correct for the pull, and also a SIB on preloading the struts to the left. Both are things a tech working at a BMW shop should know. If you are bringing these things to their attention you may want to reevaluate where the car is being worked on.
03-21-2017, 08:17 AM | #16 |
Rep 14,522
+1 with what Stuck said. i had zero issues when i brought my vehicle in for an alignment and my car is sitting pretty damn low on coilovers and they got my alignment within specs. i suggest take it to another BMW qualified shop
03-21-2017, 12:30 PM | #17 |
Rep 137
it could be that they didn't center the steering correctly while doing the alignment.
EL Jeffe 5611.50 |
03-21-2017, 05:09 PM | #19 |
Rep 76
Trying to figure out what to do :
1,My car is xdrive. Will EPS software update help? According to other posts, it only helps non-xdrive. 2,check right upper control arms angle? 3,check struts alignment? 4,Steering column replacement? 5,steering rack replacement? Thanks!
