2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum anyone having problems with the remote not detected
      09-07-2013, 12:10 AM   #1
solrac6262
Drives: bmw X5
I've been having problems with my remote lately and today the dealer changed the batteries, but I think for some reason I still can't unlocked the car without the key and also I get this error message ..
      09-07-2013, 01:41 AM   #2
Hoa
your battery may be low
      09-07-2013, 08:19 AM   #3
solrac6262
Drives: bmw X5
The stealer changed the battery, I'll switch remotes today might check the other one see how that one works
23 BMW X6MC
21 Porsche Cayenne S Coupe
      09-07-2013, 10:27 AM   #4
GringoEd
Drives: 2014 550i MSport
Why is the dealer involved in changing the battery in a BMW remote? Is a special tool required to access the the battery compartment? I am awaiting delivery of my 2014 550i with Comfort Access, and I am really curious about being tethered to the dealership for trivial maintenance?
      09-07-2013, 10:59 AM   #5
The X Men
Drives: 2013 X3 35i
I guess its part of the troubleshooting process.
      09-07-2013, 01:41 PM   #6
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
Have you tried touching the end of the fob to the lower right corner of the steering column to re-synch the fob to the car? There is a shape marked on the steering column where the fob should be held while starting the car. This is how new fobs are synched. Can't hurt to try!
Good luck!
Regards,
MWPos
      09-07-2013, 03:33 PM   #7
solrac6262
Drives: bmw X5
thanks MWPos I'll do that today
      09-07-2013, 04:14 PM   #8
Gilgorm
Drives: 2018 640i Xdrive GT
[QUOTE=GringoEd;14627886]Why is the dealer involved in changing the battery in a BMW remote? Is a special tool required to access the the battery compartment? QUOTE]
First off, they should change the batteries first in their diagnosis, which appears to be unsuccessful so far.
The door on the remote pops off very easily and the batteries are simply watch style (CR2450 in 2012). Your manual indicates the install instructions which does NOT require a special tool.
Unless things have changed the batteries are covered under warranty anyway so let the dealer do it. I suggest you change both remote batteries when the time comes.
2018 640ix GT; Alpine White, Blk Nappa, Piano; M-sport, Premium (Ceramic, SIRIUS, Soft-close, Vent/Massage Comfort seats, Surround, Sunshades, Parking Ass't), Advanced Driver Ass't (Lane keep, Steering/Lane control, Cross traffic, ACC with Stop/Go), Smartphone, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i, 12 BMW 535i X-drive
      09-07-2013, 06:58 PM   #9
solrac6262
Drives: bmw X5
I think I'm having a little bit of issues closing the doors by just touching the handle.. its like the sensor is not receiving the signal from the remote..
      09-08-2013, 08:20 AM   #10
snj1013
Drives: 2011 528i
+1, mine is doing the same. The receiver is apparently going bad.
      09-09-2013, 12:24 AM   #11
skalberti
skalberti's Avatar
Drives: 2017 Mineral White M3
To the OP, Are your windows tinited? If so is it a metallic content tint? If you have your phone in your pocket and your keys are in the same pocket, your phone will cause interference with your remote. Especially if you have an iphone. These are two issues i've found with the comfort access remotes. Solution, get ceramic tint and put your key in the pocket opposite your phone.
It's good to be bad
      09-09-2013, 08:07 AM   #12
solrac6262
Drives: bmw X5
Hello, no actually I did removed the tint and a couple of weeks ago my car was working just perfect
23 BMW X6MC
      09-10-2013, 05:27 PM   #13
nabego
nabego's Avatar
Spain
Hello, I am having the same problems, my comfort access fails sporadically and worked perfect before.
And I changed the batteries.
In the bmw have told me that the antenna can be.
      09-10-2013, 11:30 PM   #14
solrac6262
Drives: bmw X5
the antenna ? receptor going bad
      07-01-2014, 09:12 PM   #15
mko9
mko9's Avatar
Drives: '11 535i
I get the same error message you show if I am in the car with the engine running and any door is opened. The key is sitting 12" away on the center console and the engine is already running, so the error makes no sense. I asked the dealer and they were clueless. I replaced the remote battery today, but still get the error.
Any suggestions?
EDIT: This happening with both keys, and both batteries have been replaced
Mike
'04 330i ZHP
'11 535i
      07-02-2014, 07:31 AM   #16
Deslypher
Drives: F10 550i
I had the same issue, dealership replaced my key under warranty and the problem went away
      07-03-2014, 12:44 AM   #17
snj1013
Drives: 2011 528i
Any suggestions?
The receiver in the steering column or under the cup holder is bad, have your dealer replace.
      07-03-2014, 06:38 PM   #18
psyxologos
Drives: E46 330 ci SE, F11 530d SE
I have had that message twice in the last two years at random and never again. It seems there was something making the car think the key was removed. No problems since...
      07-04-2014, 05:51 AM   #19
Noggie
Noggie's Avatar
Norway
285
Drives: E31 850i,i3s
I asked, and BMW said that changing the batteries were part of the service, and would be done at every service interval.
Guess that means bringing both keys when having the car serviced.
I have also gotten that message, but I keep my key in my pocket all the time, so if I start the car and exit the car i.e to lock my front door or get the mail, I get the same message, however the car is still running.
      07-05-2014, 08:00 AM   #20
ZenHillbillyPoet
Drives: 2014 520d
Are you near any big radio towers when it fails? My dealer told me he received many distress calls about the comfort access not working in a particular part of town and they figured it had something to do with nearby interference.
      07-05-2014, 11:41 AM   #21
mko9
mko9's Avatar
Drives: '11 535i
In my case it happens with either remote, everywhere, anytime a door is opened while the car is running.
Mike
'04 330i ZHP
'11 535i
      07-05-2014, 09:56 PM   #22
TheGr8Swami
TheGr8Swami's Avatar
Drives: 2012 550i M-Sport w/XDrive
I had the same issue and the dealership actually had to recode a new key. I had them replace the battery and the car still didn't recognize the remote/key fob.
If your car is still under warranty this service is free! The dealership will make a copy of your license and registration for proof of ownership, and recode a brand new key from the VIN. The process takes about a day.
2012 550xi MSport - everything but TV's in the head rests!
