06-17-2016, 07:14 PM | #1 |
Rep 465
40,000 Mile Service
Looks like my car is due for service at 40,000 miles. Anyone know what is done during this service?
2013 F10 535i M-Sport Alpine White Oyster/Black OEM M5 Exhaust with Resonator Delete |
06-17-2016, 11:12 PM | #2 |
Rep 14,522
here's what they did for me:
Inspect / Adjust / Change Change Rotate Tires Inspect / Adjust / Change Replace engine oil and filter Inspect / Adjust / Change Inspect windshield wiper and washer systems and fluids levels Inspect / Adjust / Change Inspect suspension components Inspect / Adjust / Change Inspect steering linkage Inspect / Adjust / Change Inspect power steering fluid level Inspect / Adjust / Change Inspect half shaft dust boots Inspect / Adjust / Change Inspect exhaust system Inspect / Adjust / Change Inspect engine accessory drive belt Inspect / Adjust / Change Inspect coolant recovery reservoir Inspect / Adjust / Change Inspect clutch operation Inspect / Adjust / Change Inspect brake fluid level Inspect / Adjust / Change Inspect automatic/manual transmission fluid Inspect / Adjust / Change Inspect air cleaner/element Inspect / Adjust / Change Check turn signals and hazard warning lights Inspect / Adjust / Change Check shocks and struts Inspect / Adjust / Change Check radiator, coolers, heater, and A/C hoses Inspect / Adjust / Change Check battery, exterior lamps, and horn operation Inspect / Adjust / Change Replace cabin air filter (if applicable) Inspect / Adjust / Change Inspect wheel ends Inspect / Adjust / Change Inspect parking brake system Inspect / Adjust / Change Inspect driveshaft and driveshaft/propeller shaft U joints Inspect / Adjust / Change Inspect cooling system hoses and clamps Inspect / Adjust / Change Inspect brake system Inspect / Adjust / Change Inspect ball joints
06-18-2016, 12:58 PM | #3 |
Rep 465
Considering i have a resonator delete and a M5 muffler on my car, will that cause any issues?
