2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications n63 valve seals and oil consumption
      07-23-2016, 03:17 PM   #1
thetrance
Drives: 2019 M550i
so I had my valve seals replaced and intake ports cleaned but the car is still burning around a liter every 3000KM. what else would be causing the oil consumption and whats the fix?
      07-23-2016, 07:49 PM   #2
Zer0Cool92
Drives: blue metallic
My friend is telling me to do my valve seals . How much is a job like that and how long does it take ? Did you notice a difference after you got it done ?
      07-23-2016, 09:33 PM   #3
550Reasons
550Reasons's Avatar
Drives: F10 550i
check the crankcase vent lines
2011 550i
2013 M5
2014 M5 CP
2016 550i
      07-23-2016, 11:29 PM   #4
thetrance
Drives: 2019 M550i
already replaced!
      07-23-2016, 11:32 PM   #5
thetrance
Drives: 2019 M550i
I had it done under warranty, but I can tell you that they can do it without having to remove the engine so it will cost less. they also just slightly lowered the engine to do the carbon blasting, otherwise the replacement of valve seals does not require engine removal
make sure its actually the valve seals that's the problem.... ie smoke from tailpipe when car is idle and you tap the gas. mine didn't have that symptom
I didn't notice any difference, except no more vibrations cruising at low rpms. that has definitely improved. I assume that's because of the intake ports being cleaned not the valve seals themselves. I still get tons of soot on the exhaust pipe and burn about the same oil as before, maybe slightly less
      07-23-2016, 11:34 PM   #6
Zer0Cool92
make sure its actually the valve seals that's the problem. ie smoke from tailpipe when car is idle and you tap the gas
I didn't notice any difference. I still get lots of soot on the exhaust pipe and burn about the same oil as before, maybe slightly less
Ya my car has white smoke at idle and I had an exhaust video when I was rolling and when I floored it, big puff of white smoke came out the back. You have any clue how much the dealer might charge, as I'm out of warranty. I'm at 71k miles
      07-26-2016, 10:20 PM   #7
MattPro
MattPro's Avatar
Drives: '13 F10 550iX, '91 E30
Could very easily be turbos seals. Check for axial/radial shaft play on the turbo shafts.
Thanks,
Matt
2013 F10 550iX Carbon Black/MSport
BMW Fault Code DB
      07-31-2016, 06:49 PM   #8
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
      08-27-2016, 04:01 PM   #9
GooseInOz
GooseInOz
GooseInOz's Avatar
Drives: '12 550xi
Yesterday the dealer diagnosed my problem (burning oil, 2 liters over 10,000 miles) as an issue with the valve seals leaking.
They estimated it would cost $6,600 to repair. Yes, $6,600. When I balked -- because it's a $75,000 car with 80,000 miles -- they offered to discount it by 25% or just under $5k. Painful.
Probably not a coincidence that my sales guy just happened by in the middle of this to see if I wanted to look at the new 7s.
Big sigh.
Current: 2017 Porsche Macan S, 1991 VW GTI 16v, 2012 550xi with M-package, 2009 Porsche 911 Carrera S, 2006 Range Rover Supercharged
Past: 2007 550i, 2007 335i coupe, 2002 Ford Explorer, 1994 Acura Integra, 1985 VW GTI 8v, 1984 Chevrolet Malibu Classic
      08-28-2016, 04:18 PM   #10
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
Big sigh.
2 liters every 10,000 miles or so isn't bad for a BMW.
Since ownership, I've been topping off 1 liter every oil change.
      08-29-2016, 08:09 AM   #11
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Turbo cars will burn oil some more some less
if you don't wanna deal with this only solution is buy none turbo car.
      08-29-2016, 05:23 PM   #12
Secret_Asian
Drives: f10 lci luxury line
bmw now has a toolkit that allows them to do the job without engine removal which is supposed to reduce the price(or for many dealers just boost profit)
      08-29-2016, 06:26 PM   #13
Zer0Cool92
For Valve seal cleaning would you guys only have the bmw dealer do it or you think an independent bmw shop could do it?
