2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Drivetrain malfunction at highway (90mph) plz help !!!!
      03-24-2023, 04:17 AM   #1
ZAmax411517
Drives: Bmw F10 535i 2011
Hi guys, hope you’re doing well.
I have F10 535i 2011 126k mile on it.
The car runs idle with no problem, acceleration is quite normal with now issues, but on the highway at speed of 80 mile/h and more i get the massage of drivetrain malfunction and the car limits the power!!!! When restarting the message goes and runs normally until i reach the high speed and drivetrain malfunction pops up again…!!!
1- I have brake lights on the dash as i change the sensor but still not reset my front brake pads.
2- i have check light on as on diagnostic i found it catalytic converter efficiency below.
Note: below the speed of 80 mile/h the car can accelerate normally without any problems.
Plz help to recognize what’s wrong, i try to reach a spot diagnosis.
Thank your
      03-24-2023, 08:24 PM   #2
ZAmax411517
Update: upon diagnosis i found the code that
1- charging pressure control plausibility too high.
2- charging pressure control : switch off as consequence.
      03-25-2023, 11:17 PM   #3
ZAmax411517
Anyone help !!!!
      03-25-2023, 11:48 PM   #4
chipguy
Drives: 12 528i
You need to check the manifold pressure sensor.
      03-27-2023, 04:24 AM   #5
ZAmax411517
How come this sensor cause this problem?
      03-27-2023, 05:04 AM   #6
musclesmarinara75
musclesmarinara75's Avatar
Drives: 2013 BMW F10 N55 535i XDrive
2013 535 XDrive  [9.75]
It can also be your boost solenoid, that a possible culprit
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
      03-30-2023, 10:59 AM   #7
tx328xi
Drives: 2007 328xi
I have an N63 doing the SAME THING.... normal acceleration in lower gears, but at higher speeds where you spend more time under high boost, I also throw an iDrive malfunction, but mine is logging 102302 (MAF sensor)
I swapped the sensor banks & the error stays on that bank so it ain't the sensors.
https://f10.5post.com/forums/showthread.php?t=2005147
Curious to see what your issue is!
      03-30-2023, 10:49 PM   #8
ZAmax411517
Boost selonoid, check for it first
      03-30-2023, 11:21 PM   #9
ex46fanatic
Drives: E46 330ci F06 640i GC both LCI
I have that error, isn't it realated to having the ewg actuator adjusted or replaced to fix?
      04-15-2023, 07:00 PM   #10
tx328xi
Drives: 2007 328xi
just ordered a pair, thank you will give it a shot & report back
      04-17-2023, 06:06 PM   #11
DementedF10
DementedF10's Avatar
Drives: 2012 BMW 535ix
I was also going to report I have a similar issue. On highway under WOT around 90-130mph i get the same. I checked the codes and get an overboost code. I have yet to figure out the fix
      04-22-2023, 05:28 AM   #12
musclesmarinara75
What are you.. PWG or EWG... could be your wastegate is sticking just for a bit... check solenoid? PWG hose pinched maybe
      04-26-2023, 08:37 AM   #13
DementedF10
PWG on mine.
      04-29-2023, 05:48 AM   #14
Snakle535i
Drives: BMW F11 535i MSport
is your charge pipe ok?
535i F11 Msport, Masata IC, Masata Charge Pipe, Masata Turbo to IC pipe, BMS Air Intake, K+N Oil Filter, Catless DP, Stage 2.5, Brembo Brakes + EBC yellow pads.
      04-29-2023, 10:42 AM   #15
Double Nickel
Double Nickel's Avatar
Drives: BMW F10
2015 BMW F10  [10.00]
I saw these b4 wit WOT car feel good just driving normal, a new set of NGK's and the proper gap i have been boost'n since, now i keep a set just in case on the shelf. I might can find it on my MHD code history.
