2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Stuck in park, very slow or no crank, hot ground wire
      05-08-2023, 01:20 PM   #1
Jcope6565
Drives: BMW 528i
Hi Guys!
2013 528i x drive
The other day it stalled out and kicked into neutral while driver. Got it towed to my place. It is now stuck in park, it will crank sometimes but it is very slow for about four seconds and cuts out or just clicks.
I will note it had a new chain and chain guides put in about a month ago and has ran perfect since.
New battery was put in, no change. Ground wire gets hot when trying to start. I was able to turn over the central bolt so the engine is not frozen. I checked the front jump point and it is showing 12.6 V as well as the battery. The hot wire going to the alternator is showing the same. Tried jumping from the front jump points, it would slowly crank but did the same as before.
Could it be a blown fuse, ground strap, or maybe starter?
I'm going to lift it later today after work to see what the strap looks like.
Thanks in Advance!
