2010 2011 BMW 5 Series Forum F10 Which of these brands is the best to upgrade the mid speakers |
06-28-2018, 07:06 AM | #1 |
Rep 72
Hello all
I need to upgrading the front mid speakers and need to know which of these brand should i go for -Harman Kardon -Bowers & Wilkins -Bang & olufsen Appreciate your help Thanks |
06-29-2018, 12:40 AM | #3 | ||
Rep 14,521
07-03-2018, 07:58 AM | #4 |
Rep 639
Also not on your list, but I just went from the Harmon Kardon system in my f10 to MB Quart speakers and added Pioneer amps for amplification. Personally I think it made an incredible difference in sound quality.
Not sure what your budget will allow, so that may not be an option for you. Good luck! |
07-03-2018, 08:54 AM | #5 | |
Rep 64
07-03-2018, 09:41 AM | #6 |
Rep 639
I got the MB Quart QM200C set. It has the mid range speakers, tweeters, crossovers, and under seat woofers. I believe there is also the QM100C set that has the mid range speakers and tweeters with crossovers, but doesn't include the under seat woofers if you're looking for just that.
As for the amps, I have a Pioneer GM-D9500F bridged to 2 channels for the under seat woofers, and another Pioneer GM-D9500F in 4 channel mode with two channels connected to the front mid range/tweeter pair, and the other two channels unused as of now. I'm not sure what your plans are regarding getting it all connected wth the car's head unit, or what your budget will allow, but I'm personally using an Audison Bit DMI and a JL TWK-88. But even with just dropping the mid range speakers and tweeters in without changing anything else, I did notice a difference in sound quality. |
07-16-2018, 01:26 PM | #7 | |
Rep 238
Drives: 2015 M3
08-19-2018, 10:48 AM | #8 |
Rep 72
08-19-2018, 03:40 PM | #9 |
Rep 14,521
these are the K2 Power
08-27-2018, 04:06 PM | #10 |
Rep 639
I did the install all myself. Here is a fairly complete list of the components I used. I bought used items where I could. I also purchased various power cables/signal cables, and fuse/distribution blocks. In total I was able to keep the cost just under $2000. So far I am very pleased with the results. Still need to build a custom sub box that looks nicer than the cheap temporary BestBuy box thats currently in the trunk.
2x GM-D9500F Pioneer amps @ $80 each 1x JL 1000/1v2 @ $340 1x Audison Bit DMI @ $580 1x JL twk-88 @ $350 1x MB Quart qm200-c speaker set @ $400 1x JL 12w6v2 subwoofer (already had) various power cables/signal cables/connections/etc. |
09-21-2018, 10:32 PM | #11 |
25cent millionaire
252
Rep 1,220
Drives: 2020 m4 comp vert
audio frog gb 4inch for the doors and the gb10 tweeter.. if you can budget run the gb6.5 instead of the brutal 8s under the seats.. problem solved.
11-05-2018, 11:26 PM | #12 |
Rep 1
What is the cost for the various speakers, where did you buy them and did you install them or have someone else do it?
11-06-2018, 04:54 PM | #13 |
25cent millionaire
252
Rep 1,220
cost is irrelevant if it performs as needed and your expectations are met.. you can purchase on Crutchfield. I have been installing for over 25yrs. Thus I did the install myself, removing the 4s tho in the doors and have purchased a pair of a.f. 2.5 inch to go in the a pillars. hoping to get a better soundstage.. its a summer only car so this will be my winter project.
