2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Software Update for F10 535 (N55)
      10-19-2018, 12:38 PM   #1
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
Does anyone know if there is a software update that affects idle for the N55 engine? My car has been experiencing a weird idle dip shortly after startup for a few months now and I still haven't been able to get it sorted out. At first I thought it might have been worn/fouled spark plugs or a bad coil so I went ahead and replaced all 6 of each but that didn't fix the problem. I also thought it could be a problem with my BMS Stage 1 tune so I removed that as well but the problem persists. A mechanic at an indy shop suggested it could be the valvetronic motor failing, but another indy shop noted that a failed valvetronic motor will almost always throw a code and give a CEL (Check Engine Light). Anyone have any insight or experience something similar?
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      10-20-2018, 01:02 PM   #2
geminiys
Drives: 2013, 535XI & 2005 M3
Based on the year I assume you have plenty miles on the car. Do you know if Fuel Injector service was ever performed on your vehicle? The N55 design and similar design engines will have carbon build up present unless cleaning is performed regularly (60-80k miles but all depends on driving). If it wasn't done, I suggest to do this. Second use some additives to the fuel to clean the injectors. Also check for vacuum leak but if one is present it will make idle to be bad even after a few seconds after starting it.
You are using Premium Fuel, right?
2013, 535 XDrive, 112k miles
1997, 328is, 335k miles - Retired
1998, ML320, 200k miles - Sold
2018, Q5, 100 miles
2005, XC70 AWD, 160k miles
      10-21-2018, 07:39 PM   #3
bake
bake's Avatar
Car has 67k miles and I do lots of short trips so I suppose carbon build-up could be the culprit. Never did anything with the injectors. I don't really like using any of those additives to be honest. And as for fuel, yes, always premium, 93 octane from premium outlets (Sunoco, BP, etc.)
Bake
      10-21-2018, 07:48 PM   #4
You do know the good gas has those additives already, yes?
      10-22-2018, 04:03 PM   #5
bake
bake's Avatar
Yes I know that. I meant I haven't made a practice in using additional additives on top of those. But perhaps I need to look into it.
Bake
      10-23-2018, 12:44 PM   #6
jonobro
Drives: bmw f10 535i
My f10 has 110k+ you recommend changing fuel injectors if so which ones exactly thanks !
      10-23-2018, 02:36 PM   #7
MOBF10
MOBF10's Avatar
171
Drives: 2018 M3 Comp
I would definitely recommend walnut blasting. Did it to one of my other turbo cars and idle was a lot smoother after. It was also done around 60k miles too.
      10-23-2018, 09:37 PM   #8
Not as important on the N55 as it was on the N54. My dealer told me they don't do it on the N55 until they've exhausted all other avenues. BMW changed the "ventilation" on the N55 to correct the issue of carbon buildup on the N54.
bake601.50
      10-24-2018, 01:11 AM   #9
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
It’s still happening on n55 and we are seeing it more and more. Doesn’t build up to the same amount as n54 tended to, but it’s still an issue on n55
      10-24-2018, 09:51 AM   #10
MOBF10
MOBF10's Avatar
171
As long as its direct injection there will be a need for walnut blasting regardless of what was improved over the n54. Direct injection will always cause build up on your intake valves, period. Only time you can probably stop worrying is if your car is running meth daily.
      10-24-2018, 12:50 PM   #11
bake
bake's Avatar
About how much does a walnut blasting service cost? I do lots of short trips so this could certainly be contributing to my issues.
Bake
      10-24-2018, 03:06 PM   #12
Shieldze1025
Keepin' America Free
Shieldze1025's Avatar
Drives: F10 535i
Sure it would help, but it is only really NEEDED on N54's. N55's have nowhere near as much buildup. It's barely a film on N55's, I've heard of N54's looking like a clogged artery.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough"
-Mario Andretti
      10-24-2018, 04:07 PM   #13
[QUOTE=Shieldze1025;23895817...I've heard of N54's looking like a clogged artery.[/QUOTE]
I had one of those...
