2010 2011 BMW 5 Series Forum F10 Replace Strut Mounts Front F10 535i |
06-17-2021, 06:02 AM | #1 |
Rep 5
Hi all,
I recently replaced my shocks all round with Bilstein B12's. The front right shock was totally gone and the car rattled pretty bad. I only ordered the shocks and springs and had a local indy install them. Anyway the front end still rattles bad over bumps so I am going to replace the strut mounts but I am guessing that as the car is 10yo there is a good chance other bushings have gone. Has anyone got any advice on what I should be replacing (or expect to replace) with regards to bushings on the front end? The second question I have is are the top strut mounts something that I don't need to go OEM on? I see bilstein makes a version as well as vaico and sachs etc, is there a reputable aftermarket brand that anyone could recommend for the struts and bushings? Thanks |
06-17-2021, 12:07 PM | #2 |
Rep 2,591
What top strut mounts? The F10 doesn't have a bushing in the top strut mount - it's just a piece of metal and a spring pad.
2015 BMW 535xi
06-18-2021, 01:10 PM | #4 | |
Rep 1
bensk9875.50 |
06-18-2021, 10:43 PM | #5 | |
Rep 1,040
If it wore out I guess it could make a rattling noise over bumps, but I would think over something like a speed bump it would make a very easily distinguishable thump when the suspension either compresses, rebounds, or both. With brand new and much stiffer dampers, I would think this would get much worse/louder if it is the source of your noise. |
bensk9875.50 |
06-18-2021, 10:49 PM | #6 |
Rep 1,040
A common source of higher pitched suspension rattles are the sway bar end links. Sometimes manually rocking the car from side to side can cause these links to click, indicating they need replacement. Otherwise, disconnecting one end of a link will allow you to check both joints. They should be tight and have some amount of resistance.
Note: to disconnect a sway bar end link you'll need to jack both front or rear wheels off the ground at the same time to make sure the sway bar is not loaded. |
06-19-2021, 01:54 AM | #7 |
Rep 5
Thanks for all the feedback. I pulled the plastic protective cap off my LHS strut and was welcomed with a black rubber powder so I guess that confirms that the rubber has gone.
I have ordered replacements through FCP so will install them and then see what else rattles after that. BlueAngel thanks for info on sway bar end links, I'll take a look at them when I have the wheels off |
08-21-2021, 04:13 AM | #9 | |
Rep 455
On the R&R, torque those bolts to spec. Be careful not to over tighten bolts. |
08-21-2021, 12:44 PM | #10 | |
Rep 2,591
The bolts can be reused. BMW suggests them to be replaced because they come with integrated locktite. Just clean up the old locktite, apply some fresh, and you can reuse them for the life of the car. That said, yes do not overtorque them since the aluminum top hat strips very easily.
2015 BMW 535xi
08-21-2021, 09:09 PM | #11 | |
Rep 455
Sachs make mounts. Last I remember, they were $50, ea. Hard to find though. |
08-22-2021, 09:25 AM | #12 | |
Rep 2,591
Edit: Time-sert, not timerserted
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial Last edited by Unspec; 08-22-2021 at 11:15 AM.. |
08-22-2021, 11:15 AM | #14 |
Rep 2,591
2015 BMW 535xi
08-23-2021, 08:09 AM | #16 | |
Rep 1,873
On the updated strut top mounts the hole are untapped and the bolts tap them the first time. I believe I've seen it written that beyond two tightens you should not reuse the top mounts. Lots of "single use" stuff going on with all this aluminum in these cars. It's frustrating, but I usually just follow directions and replace it. Especially when it's in brakes, suspension, etc... Lots of people say "I had no problems". Then you see other posts where the rear shock bottom bolt simply broke on the highway. Related? Maybe? By the time the "problems" crop up, the vehicle owner (or next vehicle owner) may not associate the "problem" with the "short cut" anymore. For myself, personally, when I did my KWs it was far easier (and not very expensive when using places like FCP) to get new hats and bolts all around. This let me build my KWs on the workbench in advance of even starting the work, and without needing spring compressors and crap to disassemble the old parts which I have stored away "just in case". |
08-23-2021, 12:05 PM | #17 | |
Rep 2,591
IIRC the rear bolt breaking on the rear shock is due to not properly torquing the bolt in and introducing excessive fatigue stress.
2015 BMW 535xi
08-24-2021, 05:15 PM | #18 |
Rep 1,040
Can't know for sure without looking at the fracture signature of the bolt, but what we know suggests an under torqued bolt could have been responsible.
