2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Biggest wheel spacer without extended studs
      06-05-2018, 05:25 PM   #1
MOBF10
MOBF10's Avatar
171
Drives: 2018 M3 Comp
Hi guys. I have a bone stock 535i msport. Stock height, at the moment and will likely go with H&R lowering springs since I liked the drop, with stock msport wheels. Can I get away with a 10mm spacer in the rear without having to buy extended studs? Or is that too much length? I just want to have a nice flush look after the spring install. Thanks.
      06-05-2018, 10:30 PM   #2
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
You need extended lug bolts with 10mm spacers. BMS 10mm spacers some with the extended bolts.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
MOBF10171.00
      06-06-2018, 04:00 PM   #3
ReyNLyanne
Drives: carbon Black 2014 535i
Bms sells 10mm spacers and if I’m not mistaken they include the extended bolts for the type of spacers you get.
MOBF10171.00
      06-06-2018, 04:01 PM   #4
ReyNLyanne
http://www.burgertuning.com/BMW_wheel_spacers.html
MOBF10171.00
      06-07-2018, 01:31 PM   #5
MOBF10
MOBF10's Avatar
171
Thanks guys
bake601.50
      06-08-2018, 03:04 PM   #6
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
I got the ones from Burger Tunning as well. I have 10mm on the fronts and 15mm on the rears. Also lowered on H&R sport springs
More photos here: https://f10.5post.com/forums/showthr...293245&page=14
      07-06-2018, 03:51 AM   #7
Z10M5
Drives: 2014 535i
I got 10mm in the front and 12mm in the back, and i cant use my oem wheel locks on the 12mm. But on the 10mm they barely thread on. Its fine tho cuz its only one bolt out of 5. I wouldnt recommend using stock bolts on 10mm
      07-07-2018, 09:21 AM   #8
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
3mm spacers on stock lug bolts are sketchy, 5mm spacers get about 2 threads of engagement into the hub with stock lug bolts. Enough to hold the wheel on for a picture but not enough to drive on certainly.
You want bolt engagement equal to the diameter of the bolt into the hub.
      07-07-2018, 10:15 AM   #9
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
I wouldn't use any OEM parts after 5mm spacers. Be safe and invest in aftermarket extended wheel locks. But it also depends on where you live, I dont have wheel locks on my car for that reason. Its honestly a pain when I have to take the wheels off for whatever reason to have to go get the stupid wheel lock key from the trunk and like guard it with my life. Now I just use the same socket for all 20 bolts.
There is a reason why there is 5 bolts and not 4 bolts. Factor mainly such as balance.
      07-07-2018, 04:10 PM   #10
trbo_bmw
Drives: 2011 535i
I just put some Rohanna wheels on my 535i and I’m not happy with the fit, but kinda worried about adding spacers from fear of wheel coming off while driving, do you guys run spacers with no issues? ( with the extended bolts of course )
      07-07-2018, 06:38 PM   #11
Stück
Stück's Avatar
There is absolutely nothing wrong or unsafe about a quality hubcentric spacer with appropriately lengthened bolts.
      07-07-2018, 06:56 PM   #12
trbo_bmw
Drives: 2011 535i
Awesome, thanks 👍🏼
