10-27-2021, 10:30 AM | #1 |
Rep 28
Bimmercode error
Hi, I tried to code MPerformance logo on my Kombi and it failed to do so and now I'm getting more errors in Kombi and it shows that there is no coding data in Kombi. I tried to code it back to normal using backup in BimmerCode but there is no backup in BimmerCode app. So I tried to code it using Esys and in the TAL processing page it shows only few ecu's like ASCM,Kombi and two seat modules. I tried to code the Kombi alone as the Kombi CWFD is not present and it could not code. So I tried to do "Detect CAFD from SWID" and to code it and I'm still getting the same error. Can someone help me with this issue? My ISTA version is 4.24.30 and my ESYS version is 3.30.1. I have attached the log that I got from Esys too.
Caf's suchen Tal wird generiert Abarbeitung wird gestartet Read SVT before TAL execution started. Read SVT before TAL execution finished. TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197] ExecutionID=2021/10/27-20:40:23.476 [] prepareTALExecution started [PROGRESS] [] prepareTALExecution finished [PROGRESS] [] prepareVehicleForCoding started [PROGRESS] [] prepareVehicleForCoding finished [PROGRESS] [KOMBI - 60] prepareECUforCoding started [PROGRESS] [KOMBI - 60] prepareECUforCoding finished [PROGRESS] [KOMBI - 60] authenticateECUforCoding started [PROGRESS] [KOMBI - 60] authenticateECUforCoding finished [PROGRESS] [KOMBI - 60 - cafd_00000069-009_000_039] Transaction type: cdDeploy; Message: TA started [TRANSACTION] [KOMBI - 60 - cafd_00000069-009_000_039] Transaction type: cdDeploy; Message: TA finished [TRANSACTION] [KOMBI - 60] finalizeECUCoding started [PROGRESS] MCDDiagService<id=80714, job=com.bmw.psdz.jobs.uds.MCD3_FinalizeECUCoding, service=WDBI_CPS - WriteDataByIdentifier Codierpruefstempel, description=error: negative response : generalProgrammingFailure, link=KOMBI_60_ETHERNET> [DIAGSERVICE] [KOMBI - 60] finalizeECUCoding error [PROGRESS] [] job failed with negative response error: code: service returned global negative response description: Service WDBI_CPS returned a negative response with response code generalProgrammingFailure; LinkName: KOMBI_60_ETHERNET severity: ERROR [THROWABLE] [KOMBI - 60] There was an error during TAL execution, please check the log files. [WARN] [KOMBI - 60] - [Exception - KOMBI - 60] job failed with negative response error: code: service returned global negative response description: Service WDBI_CPS returned a negative response with response code generalProgrammingFailure; LinkName: KOMBI_60_ETHERNET severity: ERROR [] finalizeVehicleCoding started [PROGRESS] [] finalizeVehicleCoding finished [PROGRESS] [] finalizeTALExecution started [PROGRESS] [] finalizeTALExecution finished [PROGRESS] TAL execution finished [TAL_EXECUTION_FINISHED] TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "10s". [C206] Read SVT after TAL execution started. Read SVT after TAL execution finished. Abarbeitung beendet |
10-28-2021, 05:05 AM | #2 |
Rep 36
did you manage to get this sorted? if not pm me ill help
OnlyGerman363.50 |
