02-02-2021, 11:19 PM | #1 |
Rep 18
Bang e olufsen upgrade
HI everyone I found a bang and olufssen amplifier from a friend, but for f15, to replace my logic7, can I encode it and put it in my f10 because similar or should I flash it? advice?
02-03-2021, 06:31 PM | #2 |
Rep 951
Not that easy a swap. The B&O system connects individually to each speaker/tweeter and has a extra mic connection that modifies speaker outputs in real time. Also, it requires to be connected directly to the battery fuse F509 with thicker wires (50A fuse). You'll also need to change the MOST connector and use an additional connector that takes the single low power wire that is currently attached to your MOST connector and plugs it directly to the 32 pin additional connector on your B&O Amp. Now if your car has ASD you might have some of this wiring minus the power wires, already done from factory but again, if you really want the B&O experience, you need to swap out ALL speakers, and especially the tweeters since they get directly connected to the B&O AMP. Else, you might have a worse experience than your current HK setup.
08-21-2022, 06:41 AM | #3 | |
Rep 6
I think you're the guy to ask on this retro fit Can you provide the pins outs for the 32 pin connector What are the pin locations for the 7 tweeters What are the pin locations for the dual mic (Bluetooth and mic for amp) What is the pin location for the single wire I need to move from MOST connector into 32 pin connector I appreciate your input and time Best wishes D from Brooklyn NYC |
