2010 2011 BMW 5 Series Forum F10 Bavsound Revenant vs. Powered sub in the trunk |
05-21-2020, 05:17 PM | #45 | |
Rep 441
I think this sub is going to pay for itself in gas savings...I'm enjoying driving like a normal person listening to music, instead of just redlining through gears for fun every time
2013 535xi M Sport (PWG) // PS2 // Spool fx150 // MHD // xHP // FTP Inlet // FBO: AR HF DP, Wagner IC, BMS Intake, VRSF CP
05-21-2020, 07:00 PM | #46 |
Rep 500
8 gauge is fine for 40amp. But watch out there are 2 types of cable, CCA and OFC. One is pure copper another is copper clad aluminium. The best is getting OFC which would be more expensive but better in conductivity. Some people running 1000w amp have problem with very hot CCA cable. Try search for recommended wire gauge for the wattage needed.
lsturbointeg9158.50 burro_blasta131.50 |
05-21-2020, 07:00 PM | #47 | |
Rep 14,521
i'm a music guy even tho lately i've just been enjoying the the new exhaust note i'm getting from the VRSF catless DP and the TurboSmart BOV but i'm hoping this new audio systems turns out to be what i'm hoping it to be did you have to play around with the sub placement? the 3.5mm jack to RCA i ended up ordering a 6' length just so i have the ability to face the sub forward or backward depending on how it sounds. i'm wondering how much of a difference with the ski port open or closed? placing my order on the MATCHUP7BMW tomorrow as i scored a deal for $799 i think i have everything covered except all my cars i dyno matted them so i'm wondering if i should go ahead and do the BMW too?
05-21-2020, 07:04 PM | #48 | |
Rep 14,521
05-22-2020, 12:27 PM | #49 | |
Rep 441
I bought rubber washers and put them behind my license plate screws and that fixed the license plate rattle, the trunk rattles some if it's really blasting but even then it's not awful so far. I'd do the "wait and see" approach before buying a bunch of dyno mat
05-22-2020, 02:51 PM | #50 | |
Rep 14,521
i was pretty sure when i took my trunk lid apart the license plate assembly looks like would be a good baby rattle once the system was in place. the rubber washers sounds like a good idea. i maybe use double sided tape also just to hold the license plate in place as well. if it still rattles i will dyno matte the whole trunk lid. cause nothing more annoying than sitting at a light and the people next to you is laughing cause your trunk is vibrating like a bat out of hell
Jamesmick131.00 |
05-26-2020, 10:41 AM | #51 |
Rep 441
Great pics, it's perty for sure.
I'm noticing more trunk rattle now. I think dynomat will have to happen at some point.
lsturbointeg9158.50 |
05-27-2020, 06:00 PM | #53 | |
Rep 14,521
I'm showing the MatchUp 7BMW still in transit as well as the Speaker harness for the components and the subs. Just received the 3.5mm jack to RCA. Slowly but surely parts are showing up
05-30-2020, 05:58 AM | #54 |
Rep 14,521
Matchup 7BMW
Jamesmick131.00 |
05-30-2020, 05:59 AM | #55 |
Rep 14,521
all ready to go!
here's something i wanted to share in case anyone was interested or if they were looking into upgrading their system. this auto remote feature is pretty sweet as before with the addition of any amps you would have to find a acc source that would remote turn your amp on when the car is turned on. the Matchup7BMW amp sends a signal through the LINE OUT which if hooked up with a RCA to 3.5mm jack activates the RF amp to turn on when plugged into the REMOTE INPUT as pictured. than when the car is turned off the RF than doesn't detect the signal anymore which than turns the RF amp off. this auto detect is a very nice feature as it eliminates me from having to tap into the wiring harness looking for the acc remote wire. I ordered a new 3.5mm cable to have just one RCA out vs having two with one dangling
ezaircon4jc4483.50 Jamesmick131.00 |
12-30-2020, 09:50 PM | #56 |
Rep 441
Update here...love the RF powered sub, now decided to update the amp.
Was going to get the Match Up 7bmw but then I saw that Bavsound has the next generation revenant "revenant pro" coming out in March. Haven't seen anyone mentioned it around here. Seems like a nice upgrade to the Match and I pre ordered it. At $1k I figure it's worth ~$200 more than Match bc it's more powerful and comes already tuned by Bavsound... SPECIFICATIONS: OUTPUT POWER RMS/MAX TOTAL: 800 / 1600 Watts (8 x 100 Watts @ 2 Ohms RMS) DSP PROCESSING POWER 295 MHz (1.2 billion MAC operations/second) FREQUENCY RESPONSE 2Hz - 23.5kHz DSP RESOLUTION Fixed Point Native 32-Bits S/N RATIO S/N Ratio 1V 1:1 - 107.1dB • S/N 4V 1:1 - 108.dB
12-31-2020, 03:16 PM | #58 | |
Rep 14,521
12-31-2020, 05:55 PM | #59 | ||
Rep 441
I dont know details about HK except this was also in the email with specs from bavsound: "The NEW Bavsound Revenant PRO is the world's first plug-n-play amplifier to work with BMW premium audio systems. Including: Harman Kardon, Logic7, and DSP premium audio systems."
12-31-2020, 07:00 PM | #60 | |
Rep 14,521
12-31-2020, 07:15 PM | #61 |
Rep 500
Bavsound normally will come with pre-tuned profile and they locked it with a password. If you go for custom speakers, I would get Match amp. Note that the new amp is 100w/ch for 8 channels. For UP7BMW, it's 5 channels 60w + 2 channels 160W. UP7BMW is a better fit for HIFI system due to higher wattage for underseat sub.
12-31-2020, 10:08 PM | #62 | |
Rep 441
Since I have the sub in the trunk, it seems like Revenant Pro is a better fit for me than Match because the main goal of the amp is extra power to my speakers - less important are the under seat subs - let me know if I'm thinking about that wrong?
01-01-2021, 03:34 AM | #63 |
Rep 500
Personally I feel the 60w to 100w is not much. For every extra 3db loudness, you need to double your power. Depends on your speakers sensitivity and you can calculate the wattage you need. So far I don't even push more than 30w per speakers and it's very loud in my sound system. My car speakers is rated at 87db/w @ 4 ohm. I also have a 500w subwoofer in the trunk. My goal is to ensure my overall system will be able to hit peak 100db for speakers and 110db for subs with very low distortion.
87db - 1w 90db - 2w 93db - 4w 96db - 8w 99db - 16w 102db - 32w |
01-01-2021, 02:44 PM | #64 |
Rep 14,521
i would double check that because you don't want to have the lower signals going to the underseat subs since you have the sub in the rear. i'm sure the "award-winning" tuner was basing this on a factory system with no sub in the trunk. that's why i pulled the trigger on the Match because of the input pierreye gave me when i was doing my research. i have my underseats set as mid bass speakers vs subs or else it sounds muddy. that's why you need to be able to hook up a lab top and set all your parameters for your speakers.
this is where i can hook up my labtop
01-01-2021, 11:30 PM | #65 | |
Rep 441
01-01-2021, 11:37 PM | #66 | |
Rep 441
I just reread what you wrote too. If I understand your install timeline, the muddiness was when you initially plugged in the un-tuned Match amp and before your RF was hooked up. Giving Bavsound the benefit of the doubt for arguments sake, if the Revenant is tuned properly, how would adding the sub in the trunk make the underseat subs muddy? If anything I figure they'd be overwhelmed by the RF (ie not as noticeable) and it's just a lost oppty to focus them on the mids instead...in other words, if the cabin speakers are all tuned properly - including an appropriate level of mid - then shouldn't adding the RF just add more powerful bass while everything else still sounds just as good?
