2010 2011 BMW 5 Series Forum F10 Weird start up noise during cold start |
06-24-2015, 11:48 AM | #1 |
Rep 125
I have noticed that when I don't drive the car in about 2 days+, it makes a weird noise but then goes away in about 3 mins. Is this normal ? The video is not to good to hear the sound but I hope it somewhat helps. Any feedback will be great. It is a 2012 535, thanks !
Also can I post the video here through my phone? I am trying but can only add pics. |
06-26-2015, 12:23 AM | #4 |
Rep 125
Video loaded
Thanks for the advice! I uploaded it and hope this link helps. You can barely hear the noise but it sounds so weird. Tmmr morning I will try to turn it on before work just so I can get a better video (note car has not been driven since last Saturday) only turned on for the original video for less than a min a few days ago |
06-26-2015, 06:27 AM | #5 |
Rep 125
Better video
Like I said earlier I am not sure if it is normal. I think this video is better for hearing the noise and as you see after a few secs the noise drops a lot |
06-26-2015, 10:35 AM | #6 |
Rep 139
My E46 used to do this on a very cold start or after sitting for a while such as over the weekend. Eventually led to a check engine light. Codes pointed to a faulty CO2 Lambda Sensor. After further investigation turned out to be a faulty/worn coil. Hope this helps. Having listened to the rough idle ... I would be strongly inclined to investigate this route.
07-06-2015, 09:27 AM | #9 |
Homegrown in CA!
Rep 18
Drives: '11 528i
Yeah.., same noise as my 528i... Took the BMW and they found 2 failed coils... Wanted to replace all of them as each would be nearing the same point, as we as, the spark plugs for all cylinders too. Be careful... Have it checked now!
07-08-2015, 03:56 PM | #11 |
Rep 125
UPDATEE
So car went in yesterday morning for this problem and I told them not to turn it on until today because that is when they will hear it. (coldstart)
They called me just now saying that the problem is "solved, noise is gone" (have to hear it to believe it) and that they ended up replacing "the Belt tensioner and the Bolt" whatever that means haha. Will pick up the car tmmr morning |
