09-12-2016, 10:24 AM | #1 |
Rep 2,416
Enzo Performance
Hey guys, stay AWAY FROM ENZO PERFORMANCE the shop has been blowing cars up and not installing parts.
I say this because over the years i have mentioned them, they flashed Arches car which was fast but eventually had major issues and we can't prove they actually did flash it. Because car already had a flash from another company.
2011 550i RWD 60-130 7.35
09-12-2016, 01:17 PM | #2 | |
Rep 824
09-12-2016, 04:45 PM | #3 |
Like No Other.
556
Rep 1,833
I heard about this too, which was why when Arch's mentioned the tune I was a little uneasy at first. Good to see some solid confirmation. Thanks for the heads up
BMW 550i GT LCI (w/ a VW MK7 daily)
personal IG: http://www.instagram.com/TheBlackGT my work: http://www.instagram.com/CorsaAutoDesign |
09-12-2016, 05:48 PM | #4 |
Rep 205
Same here my brother took his car to enzo about 2 months later maybe 3 issues begin thank god he was under warranty 5/6 cylinder walls cracked n 4 pistons dealer had to replace his motor at 35k miles
18? 340 XDRIVE
#BM3TUNING |
09-13-2016, 01:47 PM | #6 |
Rep 163
and you told me to go to them over DME.....
2015 Alpine White BMW 550XI Msport
BMS tune, Catless Downpipes,Full Custom Exhaust, H&R springs, Avant Garde M359 Wheels, M5 Diffuser & Spoiler 2016 Race Red F-150 XLT Sport |
09-13-2016, 03:22 PM | #7 |
Rep 275
Just thought I would drop this here, our big turbo kit for the N55 made some impressive numbers, and it didn't blow up
632whp and 525wtq @25psi. Which means at 29-30psi things will get serious. We noticed a bit of a skip around 28 and suspect spark, we will be digging deeper to get every bit out of her. turbo kit with the proper fueling and ignition upgrades (and engine internals) can easily produce over 700-800 at 35-40 psi. Also we are now accepting names for the N55 Big Turbo Group Buy list. We are thinking 15-20, so please get on it before it's too late. We already have 5 spots taken. |
09-13-2016, 04:12 PM | #8 |
Rep 2,416
i was not aware of the stories yet, ive been sending everyone there because of arches car. maybe since then it got worse. but when i see IG account flooded with complaints i have to let people know. That i no longer recommend them.
09-13-2016, 05:20 PM | #9 |
Dream crusher
984
Rep 2,421
Post links of good and bad experiences. Seems like Enzo was doing good things for people on the east. Wonder if people blew their shit up because of poor maintenance or tune...
IG: @bmwdoubles |
09-13-2016, 06:13 PM | #10 |
1506
Rep 676
Drives: '17 F31 340xi US Spec
Solder? There should not be any solder on the ECU unless chips were knocked off while tuner opened up the ECU.
09-18-2016, 10:49 PM | #11 |
Dream crusher
984
Rep 2,421
Woah! That shit cray!
IG: @bmwdoubles |
09-18-2016, 11:21 PM | #12 | |
Rep 5,357
THANKS!! |
09-18-2016, 11:56 PM | #13 | |
Like No Other.
556
Rep 1,833
09-19-2016, 02:50 AM | #14 | |
Dream crusher
984
Rep 2,421
30psi is spark blow territory for sure... @enzo can you guys put up some info showing owners fault?
IG: @bmwdoubles |
09-20-2016, 03:24 PM | #15 | |
Rep 2,416
damn mop3s removed his account....
FSociety3812.50 |
09-20-2016, 03:37 PM | #16 |
Rep 2,416
here comes more https://www.instagram.com/i_whine_ctsv/
FSociety3812.50 |
09-21-2016, 02:01 PM | #17 |
Rep 275
For all you N55 guys out there.Sorry for the delay. Just gathering all the bits and pieces of the kit we need to get these rolling out. For starters we have been getting a lot calls regarding how our kit compares to other "bolt-on" stock replacement turbochargers. The very simple response is it doesn't, in anyway.
1. For starters our package removes/disables the electronic waste-gate(EWG), factory Diverter Valve and MAF sensor. Our unique ECU Calibration allows for a CEL Free operation, no drive-train malfunctions, no faults with added use of a TiAL wastegate and an optional TiAL BOV. The ECU calibration allows for a MAFless operation that now uses speed density (MAP Sensor). 2. Our Tubular Manifold utilizes a V-Band flange. Making switching turbine housings possible along with changing complete turbo assemblies, GT30,GT35,GT40 etc. Did we mention our manifold is completely designed and fabricated in house. 3. The Garrett 3586 included in our kit comes alive at 25 psi (it can operate upwards up to 40 psi) 4. All oil and coolant lines are custom assembled in house using only the best AN hoses and fittings. We decided to go with AN due to the reliability and flexibility of changing line configuration depending of vehicle model. 5. At low boost (16-18psi) we experienced 560whp, 26psi psi, 632whp. With proper fuel, ignition, clutch, engine upgrades power levels closer to 750-800hp are completely possible. Our kit will include the following. -3586 Ball Bearing Turbocharger -Enzo Performance Tubular Manifold -Custom Coolant and Oil Lines/AN Fittings -Custom Downpipe/Wastegate dump and hardware -Enzo Performance Custom ECU Calibration. -TiAL Wastegate and optional BOV -Custom Charge and intake Piping with High Flow Air-filter. -Hallman-Pro Boost Controller with Vacuum fittings and Lines We are limiting our Group Buy purchase price to the first 20 participants. We already have a few names on the list so please email info@enzoperformance.com if you are seriously considering our package. Current group buy pricing will begin at $7685. Expect that number to approach closer to $9650 when the group buy is over. For any questions please give us a call 631-920-6699 or email us today. We look forward to pushing the N55 platform, please join us Oct 2nd Sunday BBQ for a more in depth look into our turbo kit. Recommended supporting modifications. -Port injection -Enzo Performance TiAL BOV kit -Upgraded In-tank E85 Fuel Pump -JB4 For logging and Map switching |
FSociety3812.50 |
09-21-2016, 02:14 PM | #18 |
Dream crusher
984
Rep 2,421
Hot damn @enzo looks nice.
So far at 16 psi /500wtq stock turbo, internals and clutch* on my ride are alive and working. 25psi and fuel upgrades are necessary as you guys mentioned, but what about trans and internals?
IG: @bmwdoubles |
09-21-2016, 04:06 PM | #19 | |
USAF Pararescue Veteran
332
Rep 770
09-21-2016, 10:34 PM | #20 | ||
Dream crusher
984
Rep 2,421
From 600whp - 0 results may vary.
IG: @bmwdoubles |
09-22-2016, 12:16 AM | #21 | |
Like No Other.
556
Rep 1,833
09-22-2016, 09:33 AM | #22 | ||
Dream crusher
984
Rep 2,421
I trust my mechanic and tuner, but not all tuners are mechanics and vise versa.
IG: @bmwdoubles |
