2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Open air experiment and still have money for chipotle
      09-17-2016, 05:06 PM   #1
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
I know the hot air setup doesn't yield huge benefits but I felt like on the 535 it might being tuned. I removed the air box and custom fit it with silicon hoses and gave it a whirl. It feels like it doesn't try as hard through the rpm range now. Like its breathing better as I'm requesting more power. Grant it its hot air, but I have a few more experiments I will add to to this. Adding a air scoop and port the cool air directly to the air filter and compare intake temps. I also thought about removing the weather stripping around the engine (old school e90 style)
IG: @bmwdoubles
FSociety3812.50
      09-17-2016, 07:11 PM   #2
MavRick
MavRick's Avatar
688
Drives: My Wife's M
i'm just not sure the temperature of the air entering the intake makes a difference since it has to go through the intercooler, anyway. i mean...thats why you have an intercooler. compressing the air/heat from turbine wheel will heat it up a LOT more than the ambient temperature....
      09-17-2016, 07:21 PM   #3
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
True, I'm trying to increase CFM and the airbox is as hot as the engine so I don't think it makes a difference either. Porting more air at greater volume may help...
IG: @bmwdoubles
      09-18-2016, 10:22 AM   #4
paul223
paul223's Avatar
Drives: F10
I think the best solution is fit bigger diameter pipe in front of OEM box, and take out the smaller plastic pipe.
      09-18-2016, 06:04 PM   #5
MavRick
MavRick's Avatar
688
Drives: My Wife's M
yup. its the increase in the volume of air thats gonna make a difference...not the temp. its why i really want a solution to the funnel that plagues the N63 intake as it routes to the turbo. all those pipes before that funnel dont mean squat. theyre just making a bunch of noise....
      09-18-2016, 08:01 PM   #6
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Now for part of the experiment where I funnel in higher volume through skid plate scoops with dual ports. We'll see if there an increase of performance and motor bay cooling.
So far throttle response is better and there's more power on the freeway for sure.
IG: @bmwdoubles
      10-03-2016, 08:25 AM   #7
krautmeister
krrrraaauuuuut
krautmeister's Avatar
Drives: G12 750i X Drive M-Sport
G12 750i  [0.00]
That's pretty cool. So you gotta cut out an opening and attach that to your skid plate? How sturdy is it? I assume it looks like polypropylene... will you rivet?? glue never works on PP.
      10-03-2016, 08:41 AM   #8
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
wondering if getting a carbon fiber hood and just adding scoops would help?
      10-03-2016, 11:19 AM   #9
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Yes I have to cut the under tray, but gonna use a dremel with a disc stone cutter to make the perfect incision. Thought about rivets, but most likely 2 part epoxy. One vent to cool the trans another will be rerouted to the air filter.
IG: @bmwdoubles
      10-03-2016, 11:23 AM   #10
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Absolutely would work, but the cost of the hood is not worth it. Maybe buying another 535 hood off of eBay, professionally modding it to have vents and then painting it would be cheaper.
IG: @bmwdoubles
