2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Brakes covered under warranty?
      03-21-2017, 10:43 AM   #1
DigitalNav
Drives: 2013 535i M Sport
My car is still under the original 50k mile warranty (at 49K right now) and my brakes make the car shake when I presss them going above 40nph.
I called my service advisor and they said this is covered under warranty and I don't have to pay for new rotors. Is this always the case?
2013 F10 535i M-Sport
Alpine White
Oyster/Black
OEM M5 Exhaust with Resonator Delete
      03-21-2017, 11:22 AM   #2
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
Tension strut bushings are a much more common cause of shaking under brake application than actual brake friction components.
      03-21-2017, 11:43 AM   #3
gicamuci
Drives: 535ix
This is an option that was paid by the original owner (either you or someone else before you) and is some sort of an upgrade to the "free maintenance" normally included.
I had the same issue on mine and after changing the rotors the vibration was gone.
2012 Mercedes-Benz C350 4MATIC Black/Sahara
2011 F10 535i xDrive MY 01/2011 Sophisto Grey / Black
      03-21-2017, 11:54 AM   #4
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
Correct. There is two types of plans you can get/buy. The first is the normal warranty that fixes stuff if something breaks or is going bad. The second is the maintenance plan. The maintenance plan is when you pay up front for all the services for a time period or miles. And luckily it was still transferable (from what I know, its not anymore).
      03-21-2017, 12:07 PM   #5
DigitalNav
Going to call my SA again and get some facts. Is it better to go to the dealer if I have to pay or should I get some after-market ones around the same cost that are better or cheaper?
Alpine White
Oyster/Black
      03-21-2017, 01:26 PM   #6
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
Its all depends on your skill level. If you are able to do it at home (or somewhere cheaper that you trust) then go that route. Personally brakes and rotors is a good DIY to learn and will save you hundreds, if not thousands.
      03-21-2017, 02:13 PM   #7
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
If you're under the ORIGINAL 4YR/50k mile warranty then you are covered 100%. If you are under an EXTENDED warranty plan through the dealer then you would have had to also purchase the extended MAINTENANCE plan through them to have this covered.
Ickdeep5718.50
      03-21-2017, 02:51 PM   #8
DigitalNav
Alright so called in the knick of time, 800 miles left till 50k warranty runs out. Getting them replaced free Thursday!
Alpine White
Oyster/Black
      03-21-2017, 03:47 PM   #9
cipher5
cipher5's Avatar
Drives: 2020 Donington Grey X3M Comp
Good call, get them replaced for free from the dealer. Then after those wear, you can upgrade to an aftermarket set.
      03-21-2017, 04:06 PM   #10
TTG
TTG's Avatar
Drives: M340
Not in the US.
1. If you are the original owner of the car, everything is covered besides pretty much tires and gas 1st 50k or 4 years.
2. If you are NOT the original owner of the car BUT car entered into service before July 2014, above still applies. (As in OPs case) However, I do remember reading recently about rotors not being covered as well.
3. If you bought the car used and if it entered into service after July 2014, you are on your own unless some sort of an additional maintenance plan or warranty was purchased.
BMW canceled their free maintenance plan unless you are the original owner in the US in 2014 which is a bummer.
Someone can correct me if I am wrong.
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
      03-21-2017, 04:52 PM   #11
DigitalNav
Just curious, how many miles should the brakes/rotors last with spirited driving?
Alpine White
Oyster/Black
      03-21-2017, 04:54 PM   #12
Stück
Stück's Avatar
50k is what I've come to expect out of these late model BMW's on the first set of factory brake consumables.
      03-21-2017, 07:37 PM   #13
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
With spirited driving? I purchased my vehicle after a lease return and the front rotors were shot at 33k miles. Warranty replaced the whole front braking system. Rotors, pads, and calipers.
      03-22-2017, 07:58 AM   #14
BlueTangClan
Drives: na
Mine shaked when I apply the brakes between 70-80 mph. I had the rotors turned with new pads and its all good now.
      03-22-2017, 04:33 PM   #15
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Lucky Dawg
      03-22-2017, 04:34 PM   #16
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Turning is way to go I always do it until they tell me they cant do it no longer on all my cars.
      03-22-2017, 04:52 PM   #17
Stück
Stück's Avatar
Replacing calipers is NOT normal, much less at 33k mi. Your car was likely an anomaly and or beat hard.
My 14 535i just ticked over 25k, I still have 7mm of pad in the front, haven'y measured the rotors but they have no visible lip.
      03-26-2017, 06:52 AM   #18
krautmeister
krrrraaauuuuut
krautmeister's Avatar
Drives: G12 750i X Drive M-Sport
G12 750i  [0.00]
Man that was one of the great preowned perks for BMW! I loved it with my first BMW purchase with my E60.
(Current) G12 750i X Drive / M-Sport / LOADED
(Current) 997 Turbo / 6MT / HRE FF01, Land Rover LR3 - Overlanding Family Adventure Shed, E60 525i - "family beater", Alfa Romeo Spyder Veloce - garage art
(Gone) F10 550i / M-Sport, D2 Audi S8, AP1 S2000, Z32 300zx, S13 240sx
      03-26-2017, 08:42 AM   #19
Jayphil
Jayphil's Avatar
63
Drives: 535I xdrive 2011 (M-SPORT)
I replaced my rears at 45k miles and now my front at 52k miles.
Front OEM are expensive because of the 2 pieces style (aluminum hat).
I went to IND for the rear for 350 $CAD and not the front from 400$CAD including PAD, Rotors, sensors and installation (quality rotors and pads were used...)
Much less vs dealer.
BMW 535I xdrive 2011 M-Sport with H&R Springs, Niche Form Wheels 8.5 ET35 / 10.5 ET35, Continental DSW06 245/35 & 285/30, JB4 Map 5, ER Downpipe, Megan Racing Quad Exhaust with Vibrant resonators, M5 Diffuser, Orange reflector shaved and removed xdrive badge.
