2010 2011 BMW 5 Series Forum F10 Coding for BMW now a flick of a switch in iPad!!! |
11-13-2016, 10:11 PM | #23 |
Rep 206
I am having the same issue on my cic 535i. The car is coded with the tpms temp/psi and that works flawlessly. I also had the sport display coded but whenever I choose to switch to hp and foot lbs under lang/units it keeps getting stuck in kw and nm.....
11-13-2016, 10:16 PM | #24 | ||
Rep 357
Drives: 19' M2C
11-13-2016, 10:17 PM | #25 | |
Rep 1,287
2013 F10's have the NBT while the lci has the NBT evo. Sport displays will work on either one of them.
11-13-2016, 10:23 PM | #26 | ||
Rep 357
Drives: 19' M2C
11-13-2016, 11:16 PM | #27 |
Rep 5,357
Did you code HU_CIC 3000 EFF_DYN_SPORT_UNIT aktiv??
11-14-2016, 10:37 PM | #28 |
Rep 198
what is the difference between getting this and seems extremely simple to code our own cars for about $59 for dongle and $59 for the app and u own it, or having someone else to do it for 100?
11-15-2016, 12:22 AM | #29 |
¯\_(ツ)_/¯
170
Rep 425
well maybe for the later years you can choose between kw/hp and lbft/nm and even have it work but for my 2010 i can activate the menu but i had to code hp and lbft by myself.
earlier years can also activate the "ambient lighting" brightness but the bar will not be adjustable.... for example
30FF
11-15-2016, 01:21 AM | #30 | |
Rep 1,085
Drives: 2013 BMW F10 550 Xdrive Msport
They are adding coding all the time and if you want a specific feature, they will add it in the next revision. Great product |
11-15-2016, 04:19 PM | #31 | |
Rep 5,357
11-15-2016, 09:50 PM | #32 |
Rep 553
In case anyone needs to change the sport display units settings to be ft lb and hp, here are the functions to code:
KOMBI => DREHMOMENT => lb_ft (displays ft lb) KOMBI => LEISTUNG => ps (displays hp) And here's the sport feature: (For N63 cars the gauges appear, but do not function) (CIC) HU_CIC => EFF_DYN_SPORT_CID => aktiv HU_CIC => EFF_DYN_SPORT_UNIT => aktiv (NBT) HU_NBT => EFF_DYN_SPORT_CID => aktiv HU_NBT => EFF_DYN_SPORT_UNIT => aktiv 2014 LCI (Already in iDrive)
Regards,
MWPos Last edited by MWPos; 11-15-2016 at 10:02 PM.. |
