2010 2011 BMW 5 Series Forum F10 550i Flood Victim : Next Problem - |
03-04-2021, 03:18 PM | #1 |
Rep 2,349
Ok, so moving along here, I finally moved my 550i today on its OWN power! Just backed it out of my garage.
Ever couple feet, it would jump back into park. I was told these transmissions are Sealed, so i did not check to see if water got inside. Any insight on this would be helpful Or any other ideas as to why it goes back into park, will also go into park if i put it in gear and dont move for like a second. **UPDATE** It seems that it might be the car thinking my door is OPEN - Even when its closed. Anyone have any idea what sensors detect if a door is open/closed? Vehicle Info: 2016 BMW 550i 4.4 T Automatic Car was in a pond for 30-45 minutes. Thanks
07 E92
Jb4-G5 - Sport Exhaust - Titek BOV BBS Lm reps - AFE dual cone intake Last edited by 335iNavyGuy; 03-04-2021 at 03:34 PM.. |
03-04-2021, 05:39 PM | #2 |
Rep 5,388
Don't know about the sensor, but the trans is definitely NOT sealed. Manufacturers just use that as a "low/no maintenance" selling point. It's nothing but hype. IIIRC, ZF recommends a fluid replacement between 60K & 75K miles.
03-04-2021, 11:46 PM | #3 |
Rep 262
You may want to flush the trans, FCPeuro says an entire kit and ISTA will walk you through the process and there is a really great DIY on here. But you are correct about the door stopping you from being able to reverse, do you have a light showing the door is open on your cluster? Do you have any faults?
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
03-05-2021, 12:06 AM | #4 | |
Rep 2,349
And yes, i have a TON of faults left lol
07 E92
Jb4-G5 - Sport Exhaust - Titek BOV BBS Lm reps - AFE dual cone intake |
03-05-2021, 07:02 AM | #5 |
Rep 639
I would definitely do a fluid and pan change on the transmission. Not that difficult, especially if using ISTA to walk you through it.
I believe I read the other day about someone having the same issue with the transmission going into park and not throwing an error due to a comfort access handle being bad. If you have that option, maybe find a way to bypass the sensors in the handles and try again? |
03-05-2021, 10:32 AM | #6 | |
Rep 2,349
Next part im not sure of, is this a sensor in every door or just drivers
07 E92
03-05-2021, 11:28 AM | #7 | ||
Rep 639
03-05-2021, 12:49 PM | #8 |
Rep 2,349
Just had someone give it a try, seems only the drivers door caused this reaction in their vehicle
07 E92
