2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Rotor question... is this normal?
      03-18-2019, 11:08 PM   #1
initialM
initialM's Avatar
Drives: F10 535i M-sport
Hey guys. I noticed my front rotors have this circular indentations on my rotor. Anyone knows what it is or what causes it? Pic attached. I’ve never had any brake job done since I bought the car and the car only have <40k miles. My F10 has the M-pkg. Thanks in adv for any input
      03-19-2019, 09:00 AM   #2
Kwood-F10-535i
Drives: 2016 535I
Attachment 2013113
Yes it is fairly normal. My F10 had the same issue after 50-60k I beleve it is caused by hard braking a lot. Its safe to drive until you need pads. When the next brake job is done you will need new rotors. BMW never turns rotors they always replace.
      03-19-2019, 10:30 AM   #3
kohsin
Drives: 2013 F10 550ix
Does your steering wheel shake while braking during high speed? Usually around 60 to 80 mph. If so, there will be problem eventually before the pads worn out.
      03-19-2019, 12:02 PM   #4
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
As long as you don't feel any grinding or noise when you're braking you should be alright. Looks like an old skool vinyl record lol!
      03-19-2019, 01:45 PM   #5
TEF
2018 540d xdrive  [0.00]
2016 X3 28d  [0.00]
This is typical scoring usually when one has OE semi-metallic pads. It almost seems that the this is a deliberate effort by car manufactures to sell not only replacement pads, but the more expensive component, rotors. I've had much better luck with rotors when using ceramic pads.
Kyngofpop676.00
      03-19-2019, 03:05 PM   #6
JDMSteven
JDMSteven's Avatar
Drives: '13 F13 M6, '94 JDM Supra
2013 BMW M6  [10.00]
Attachment 2013113
Mine started looking like that at the same mileage, but my fronts were warped and I needed rear pads so at 38k I did R1 Concepts Carbon Geomet Rotors and Optimum OEp pads and they are incredible!
2013 F13 ///M6 Alpine White • Zandvoort Full Merino Driving Assistance Pkg • Exec Pkg • Vent Seats
Vorsteiner VFF-103 Carbon Graphite 343M dimensions • H&R Lowering Springs • Soul PP Resonated Muffler Delete • AeroFunction AF-1 Carbon Front Lip • Carbon Front Grilles • Carbon Mirror Caps • IND Black Fender Vents
      03-20-2019, 02:07 PM   #7
snj1013
Drives: 2011 528i
BMW Dealers may not turn rotors but they can be turned. There is a minimum thickness stamped on the inside of the rotor that can be checked by your local machine shop to determine if the rotor can be turned safely.
