2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 - N63,N63TU intake system
      03-27-2015, 12:28 PM   #111
ARC550
Drives: M3, X5, 720s, X5, 750xi
Originally Posted by Simple3 View Post
Man... you two love busting each other's balls huh? LoL
Trial and error.. Would love to have cones in-front instead of back.. I can always get mine .
      03-27-2015, 12:28 PM   #112
ARC550
Originally Posted by badblack550xi View Post
His car is basically mine considering the amount of work i did on it
ahahhahahhahahhahahhahahahhahah! Funny Guy!
      03-27-2015, 03:22 PM   #113
badblack550xi
badblack550xi's Avatar
See you Sunday
2011 550i RWD 60-130 7.35
      03-27-2015, 10:25 PM   #114
Simple5
Drives: F90 M5 and E84 X1 Xdrive35i
I would love to get my hands on this to test. Run some piping from the front up to the filters to splash some cold air from the front like Dinan...
Yo, Badblack... how much for a set of your scoops? I got a guy that works at a custom shop who said he would fabricate me a set of air filters... want to use your scoops to test...
Thanks man, let me know!
      03-29-2015, 01:12 AM   #115
badblack550xi
any shop can make them probably better than me in a garage =D
we should have working intake prototype this upcoming week just working out the MAF issues.
      03-29-2015, 01:26 AM   #116
badblack550xi
New intake system is going into production. Estimated cost will be $1000 each.
The system comes with 2X pipes, 2x filters and clamps, and heat shields for both sides. The picture shown is for a 2012 BMW 750XI.
      03-30-2015, 04:05 PM   #117
550orm5
Drives: 2011 550I
^that's an awesome video. He called the shit "poo".
      03-31-2015, 02:30 PM   #118
badblack550xi
Guys i should have a full system next weekend.
Going to track this week to see what i run after the recall campaign, after intake is in and adopted i will go to same track in similar conditions and see what happens.
      04-14-2015, 01:26 PM   #119
DesiRacing-AjayB
Drives: BMW 550i xdrive f10
whats going on the intake system?
      04-15-2015, 12:55 AM   #120
badblack550xi
more work to do 1st test did not work
      04-15-2015, 01:15 AM   #121
gclions
gclions's Avatar
78
Drives: 2011 550i
Well, I can promise you it wasn't due to a lack of effort on our end. I've got a few more ideas to bounce off you, but I need to get off night shift so I can work on the car a little.
I'm still convinced I've got a vacuum leak, as I think it's lost power. Starting with the PCV on the driver's side, then probably going to replace the driver's side tube down to the intake manifold.
I saw on another post you're getting the meth setup going again, can't wait to see how it works when properly wired.
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
      04-15-2015, 01:24 AM   #122
badblack550xi
my car runs like crap now even stock and smell of oil ....must be the extended PVC
      04-15-2015, 01:45 AM   #123
gclions
gclions's Avatar
78
Drives: 2011 550i
Yeah, I guess that was too much of a stretch for the one to the intake manifold. The one that I cut should be to my house this afternoon. I'll do a quick swap out to see if that fixes what I think is low end torque missing.
If that doesn't fix it, I may go for a few dyno pulls to see how bad it is. I never got a good torque number before, but I can use the base BMS torque number plus my previous HP number to see if I'm close.
I'm half tempted to pick up stage 2, but I'm not sure I can justify the money if I'm going to keep trying to make a functioning intake. Plus I swore I wouldn't do any more mods if the intake didn't work...I hope she knows I was kidding.
      04-15-2015, 01:48 AM   #124
badblack550xi
i ordered a new one $47 will swap and see if it fixes the issue
      04-15-2015, 01:55 AM   #125
gclions
gclions's Avatar
78
Drives: 2011 550i
You have any idea how to get the connection off the intake manifold? Or if you can access the intake manifold from under the car?
I tried for what seemed like two hours to get it off (it has one of the compressible vacuum fittings), as I think that is the real culprit. When I stretched that line to get the PCV connected I'm almost positive I did something to damage it. I feel like I'm getting lag from idle to boost, then it just jerks back to power, my guess is a vacuum leak at idle is sucking in unmetered air, then the problem goes away under boost.
That is a really tight fit between the side of the engine and the fender well, and I didn't see any sort of cover to come in behind the wheel. I'm guessing you need it to be on a lift so you can pull the cover off the bottom and reach up to get it. I would sure hate to pay the dealer $100 to swap out a vacuum line, so I need to figure out how to do it.
      04-15-2015, 08:02 PM   #126
badblack550xi
Some teaser pictures during 1st fitment
      04-15-2015, 08:42 PM   #127
MEby
Drives: Tasman Green 550i xDrive
I see something interesting lurking behind those kidney grilles.
Mike
      04-15-2015, 09:49 PM   #128
DesiRacing-AjayB
What type of rotors do you have on your 550 badblack?
      04-15-2015, 09:52 PM   #129
DrewBert
DrewBert's Avatar
Drives: 2020 BMW M8 Gran Coupe Comp
Kinda looks like the MSR intake no?
      04-15-2015, 09:56 PM   #130
badblack550xi
Yes this is same as MSR but for 550 we have a lot less space to play with.
      04-15-2015, 09:57 PM   #131
DrewBert
DrewBert's Avatar
Awesome!!! Any idea if this with fit the 650i!!
      04-15-2015, 10:00 PM   #132
badblack550xi
yes it will 550-650-750
