2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum TPM Malfunction
      03-15-2019, 09:31 AM   #1
snj1013
Drives: 2011 528i
TPM Malfunction
Will one bad/dead TPM sensor cause a TPM Malfunction where none of the sensors will show active. I have the TPM Malfunction fault for the 2nd time in just over a month, and have noticed that the right rear sensor has been "slow" to display pressure/temperatures. So will one bad sensor give a system TPM fault where no sensors display temp/pressures?
      03-16-2019, 09:23 AM   #2
JDMSteven
JDMSteven's Avatar
Drives: '13 F13 M6, '94 JDM Supra
2013 BMW M6  [10.00]
Yes that can happen, I have a 2011 so I don't get the exact tire pressure readings but BMW is weird, I only have one bad sensor right now and it just says TPMS malfunction which is silly, it should say which sensor or one of the sensors failed.
      03-16-2019, 02:19 PM   #3
emanuelvarga
Drives: 2012 F10 535xD
I've been meaning to ask this question for a while now, I got my car used a year ago and when changing the tires i notices there are no TPMS sensors inside the wheel, i just assumed that adding these sensors will not change anything as this is not supported by my car, is there a way to check if I can get real pressure reading if I were to add sensors?
Or put the question differently, is there a specific feature that the car should be equiped with to be able to read pressures?
      03-16-2019, 03:38 PM   #4
JDMSteven
JDMSteven's Avatar
2013 BMW M6  [10.00]
You might need to decode your vin and see if it's equipped with such a package
      03-16-2019, 04:07 PM   #5
wcr3d
Drives: 2013 535i XDrive M Sport
Option Code S2VBA
Tire Pressure Display
