2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Engine light won't go. Help
      03-20-2019, 02:58 PM   #1
iron331
Drives: 5 series
Heres the issue
i have a 2010 528i. I installed a cold air intake long time back and engine light came on. I used to be able to tighten it and it would go off and get my inspection passed before
Eventually i decided to get rid of cold air intake and install a used stock intake (whatever the car came with) . then the engine light went off for some time and now it came back ON and i cant seem to fix it
it gives 2c31 code. my mechanic tried everything. clean sensors and intake. install new 02 sensors both upstream and reset codes. did smoke test and found no leak on intake, still engine light will come back after 25 miles of driving
my mechanic is scratching his head now.
Anyone have any thoughts on what i should do
      03-20-2019, 03:16 PM   #2
upstatedoc
I'll get back to you
upstatedoc's Avatar
7560
Drives: blue streak
Joekerr , i'm sure you can help this man
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/
Countermeasure enthusiast.
      03-20-2019, 03:27 PM   #3
PINeely
PINeely's Avatar
Drives: 2013 535i, 2015 Tundra 1794
Do you know whether the first time the light came on (when you installed the intake) it was also the same code? And how long between taking the intake off and the check engine light coming on again?
      03-21-2019, 07:23 AM   #4
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
gas cap?
upstatedoc7559.50
      03-21-2019, 08:03 AM   #5
Joekerr
Drives: 2017 Audi S6
I thought about saying something snarky, but in an uncharacteristic display of restraint, I have refrained from doing so.
Even though I'm fairly positive the OP can read all the subforums available, including the mechanical maintenance and DIY guide subforums...but for some reason chose this subforum.
Who knows, it is OT after all, someone may be helpful.
upstatedoc7559.50
