2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Fuel-it coming out with e-85 fuel pumps
      02-13-2017, 04:08 PM   #1
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
E-85 fuel pumps for the F10 535! Found this on the gram
IG: @bmwdoubles
      02-13-2017, 04:49 PM   #2
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
So what is this for exactly? A replacement for your typical fuel pump?
      02-13-2017, 05:44 PM   #3
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
I believe it would be for the HPFP supplying a higher volume on the top end of more e85
IG: @bmwdoubles
      02-13-2017, 05:47 PM   #4
AlpineWhite13
Drives: 2013 535i m sport.
Its a stage 2 lpfp upgrade. I recieved mine in the mail last thursday. Getting it installed Wednesday
      02-13-2017, 06:22 PM   #5
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Nice what tune are you running and how much e85 are you planning on?
IG: @bmwdoubles
      02-13-2017, 06:42 PM   #6
AlpineWhite13
Im only running jb4. My hope is the get around e50 or higher so i can run map 7. Steve from fuel it says ill be able to run enough to max out the hpfp. How much that is only logs will tell. Im not real knowledgeable on what other tunes are available or flashes if any.
      02-13-2017, 07:44 PM   #7
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
What were your trim levels getting to & with how much E85 before it was decided that you need to upgrade your LPFP?
      02-13-2017, 09:26 PM   #8
AlpineWhite13
I usuall run 5 gallons of e and the rest 93 which is about e32. My trims have never pegged out at 50, usually 35-40. My fp_h stays between 12 and 14. I decided i wanted to upgrade because according to what ive read a stock lpfp wouldnt keep up with e50-60.
      02-13-2017, 11:25 PM   #9
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
would you guys have to upgrade your injectors and maybe different spark plugs? i know in the Import world i had to.
      02-14-2017, 04:03 PM   #10
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
for what reason would anybody put E85 in their car
      02-14-2017, 05:01 PM   #11
AlpineWhite13
More power
FSociety3812.50
      02-14-2017, 06:20 PM   #12
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Cooling, higher octane, less prone to knocking, smells like corn and because it makes you look cool at the gas station
IG: @bmwdoubles
AMT92389.50
FSociety3812.50
      02-14-2017, 07:10 PM   #13
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
Potential for more power. Why would anyone spend $8/gallon on race gas when you could mix $2/gallon E85 with the same result
FSociety3812.50
      02-14-2017, 08:38 PM   #14
DVaystub
DVaystub's Avatar
Russian Federation
9
Drives: 2016 F10 N55 M-Sport
2016 BMW 535i  [0.00]
2012 BMW 335i  [0.00]
Best 2 reasons!
Current
2016 F10 N55 EWG M-Sport | Jet Black | JB4 | BMS Intake | BMW Performance Exhaust
Past
2012 E92 N55 M-Sport | Mineral White | JB4 Stage 2 | BMS Performance Intake | BMW Performance Exhaust | BMS E85 FlexFuel Wires
FSociety3812.50
      02-15-2017, 10:05 AM   #15
Stück
Stück's Avatar
Let me know once you get it installed, curious to see if the EKPM throws a fault for it or not. it may not be happy with the increased current draw, and nag you on the iDrive screen. If it does I can code it to be happy with the new power requirements.
      02-15-2017, 10:48 AM   #16
AlpineWhite13
Will do thanks. Im at Europower right now getting it done
Update : no codes upon installation
      02-15-2017, 04:13 PM   #17
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
More power
CLean Powaaaa
Smells better than Gas lol
The best!
Originally Posted by DVaystub View Post
Best 2 reasons!
+1
Keep us posted, use http://www.georgebelton.com/E85Calculator.php
to do your mixture
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      02-15-2017, 05:02 PM   #18
AlpineWhite13
Ill need to get an ethanol content tester. But if the pump was true e85 , i filled up with e50. I logged and logged then logged some more. Fp_h still never goes below 12. Trims right at 40 and afr at 15. Im gonna post on n54 tech for review tonight
      02-15-2017, 05:17 PM   #19
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
how's the power at E50 compared to E25-E30?
      02-15-2017, 05:19 PM   #20
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Would be interesting to slap it on a Dynojet start at E40 pull, then E50 pull, then E60 pull until his logs show FP_H = 11 and/or Trims maxing out
Whats your FOL at ?
IG: @bmwF9XG80
      02-15-2017, 05:28 PM   #21
AlpineWhite13
I havent changed fol from the factory settings. Car definitely pulls way harder. Im on map 5. I wonder what whp im at right now.
