2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Veriable Damper Control!!!
      08-16-2016, 09:52 AM   #1
JOHNBMWM5
JOHNBMWM5's Avatar
Drives: 2022 LCI Marina Bay Blue/ Smok
Can someone explain this as I have ordered it and I was hoping it would allow me to change Suspension independent of Chassis.
Is this correct?. Thanks.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      08-16-2016, 02:59 PM   #2
Johnny Grabble
Drives: 530d
I have VDC on my F10. Basically it changes the suspension set up. Comfort+ is the most damped ride, then Comfort (which is the default on mine and also the suspension setting used with Eco Pro), then there's Sport, which is firmer, weights up the steering as well and sharpens throttle response and finally there's Sport+ which is like Sport but also switches off some of the traction control aids.
Separate to that if you have an auto box, you can play with the change up points by moving the gear lever to the left into Sport mode, which makes the engine change up at higher rpm.
Having owned F10s with and without VDC, I think you've made a good decision.
      08-16-2016, 03:19 PM   #3
JOHNBMWM5
JOHNBMWM5's Avatar
Thanks, so I can't change just suspension settings without upping engine response then?, I was hoping to set it too Sport suspension and Comfort engine settings.
EDIT: I have the sport auto box too in Sport + Pack.
      08-16-2016, 03:49 PM   #4
Johnny Grabble
Drives: 530d
Yes, pretty sure you can do that, I did in mine. Didn't like it revving madly in Sport, so adjusted drive train settings in iDrive independently of suspension settings.
      08-16-2016, 04:08 PM   #5
JOHNBMWM5
JOHNBMWM5's Avatar
Great thanks, I don't like the engine revving high all the time.
      08-16-2016, 04:16 PM   #6
HighlandPete
Drives: BMW F11 535i Touring
You'll still have the option to set to Chassis, or Drivetrain, or both. Suspension and steering together, throttle mapping and shift program together.
I check the chassis option, as I don't want the sport drivetrain active when I toggle to Sport mode. I'll use the M/S program (flick the shifter to the left) if I want temporary sport shifting. Sport+ puts it into the Sport drivetrain program anyway, even without it checked, does so in my 535i.
      08-17-2016, 02:32 AM   #7
JOHNBMWM5
JOHNBMWM5's Avatar
Thanks Pete, good to know, I like the Sport suspension on open roads but don't engine mapping most of the time.
      08-17-2016, 02:34 PM   #8
shiner
Drives: 535D MSport Touring
Well worth having. I have it on my F11 535D
2015 F11 535D M Sport Touring, Space Grey, VDC, HUD, Comfort Seats, Sport Auto, Pro Media. GONE
2013 Z4 35is + tons of options. CURRENT
      08-18-2016, 02:46 AM   #9
JOHNBMWM5
JOHNBMWM5's Avatar
