2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum After a 12 hour drive FAN GOES CRAZY while car is off
      03-23-2014, 11:30 PM   #1
tven99
GOVNER
Drives: 13' M5, 05 P71, 15 SP CHLGR
My car has been running for 12 hours,
I got back into North Carolina from NYC and I have been driving it hard the whole way, I parked the car after I arrived and went into a hookah bar for a half hour. I drove back home and after I turned my car off the car sounded like a jet, with the fans on full blast, along with a drivetrain malfunction that I got 10 minutes before my trip ended and I took an exit and stopped my car. The loud fans was making me feel bad for my neighbors since eveyone has work tomorrow. I'm thinking it's not Because of hauling ass for 12 hours, since they do that in Germany. Any thoughts?
      03-25-2014, 07:34 AM   #2
JamRWS6
Drives: 2022 X3M Competition
I've had the fans run after turning off the car when it is very hot outside. The malfunction sounds like an issue though.
- 2022 X3M Comp
- 2021 X5 xDrive 40i
- 2018 F80 M3 (sold)
      03-25-2014, 08:36 AM   #3
raleedy
Drives: 2016 228i 6-speed
Drivetrain malfunction? Sounds totally normal to me. Maybe another half hour in the hookah bar would help.
      03-25-2014, 10:16 AM   #4
bkM3
Drives: 06 M3 Vert 6MT Carbon/Black
iv noticed that alot of turbo cars have the fan running after the car is off. iv had that with my previous vw cc and my current 528xi. im assuming its just to cool off the turbo. the malfunction is obliviously not normal though.....
      03-25-2014, 10:38 AM   #5
tven99
GOVNER
The fan being on was normal, but this time it sounded like a jet, the problem disappeared until this morning, i had just arrived in school, right inside the parking lot i got the drivetrain malfunction, engine over heating, the fans going crazy, and it was snowing outside. I had only been on the road for an hour, driving normally.
      03-26-2014, 07:10 PM   #6
raleedy
Oil temp in the normal range?
      03-27-2014, 09:49 AM   #7
tven99
GOVNER
The problem started progressing, the car is at the workshop at the moment. After a few minutes of startup the car started overheating. When i took it to the workshop and when my service advisor tried to pull it into the garage, the car stalled. This is really weird, i haven't heard of anyone else having this problem with the f10 m5. My service advisor and I are both really curious about what is going on with the car.
      03-27-2014, 10:56 AM   #8
ezmaass
ezmaass's Avatar
Drives: '17 650xi GC / '15 Audi R8 V10
It's not good when your SA is "curious" Something may just be wrong with the cooling system - obviously it's overheating, you know that much. The fans may be on high blast trying to compensate. Many years ago my wife had a VW that sounded like a jet (as you described it) when we parked it, along with when the car was running. After a day or two of this, I took it in for service. Turned out that there were normally two main fans that helped cool the radiator, and one of them had failed. The other was working overtime. Obviously a different problem... but the symptom here of the loud fan tells me that the car is probably trying to compensate for some other failed component that's supposed to keep temps under control.
Good luck with it - I'd imagine a quick OBDII scan would reveal something pretty quickly.
2017 BMW 650xi Gran Coupe | MSport | Exec Package | Driver Assist Plus | ACC Stop & Go | Adaptive Drive | B&O | Night Vision | Cold Weather | Active Seats
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching
Previous: '14 550xi, '07 335i, '01 325i
      03-27-2014, 03:04 PM   #9
Gordon4499
Scotland
18
Drives: 2016 535D M Sport Touring
This could be along shot and not sure if they are fitted to US cars but catalytic converters get an auto regeneration every now and then. Normally this happens when you are driving and goes unnoticed but if it triggers near the time the engine stops then the fans will go full tilt for at least 5 mins. My old Audi did this a couple of times and I was convinced there was something wrong with the car. The dealer eventually advised me what was happening but there was nothing in the manual. You can usually tell by a smell of burning coming from under the car. As I said, may not be applicable to you guys.
      03-27-2014, 04:23 PM   #10
Super6
Drives: 2012 535xi, 2014 640i
The only thing I can think of, this last happened to me when my water pump went out. It would overheat within 5min, and the fans would sound like a jet trying to cool the car off.
      03-29-2014, 06:56 AM   #11
jellyfish
Drives: 2011 535i xdrive
Sounds exactly like what happened to my X5 (since traded in). They replaced the water pump and later the radiator.
      03-29-2014, 02:53 PM   #12
BavariaExclusive
Drives: a Spaceship
BMW takes care of that if you have an issue. Aint worried bout nun.
      03-30-2014, 09:01 PM   #13
tven99
GOVNER
I got the car back a few days ago, they tested and replaced the fans. Right the next day after school I started my car (cold start) the car wasn't even at operating temperature the fans started blasting again. I took it to the workshop again and parked it there. The entire dealership could hear my fans. I think something is seriously wrong with the car, when my sa tried to start the car again to move it it stalled.
      03-31-2014, 12:33 PM   #14
ezmaass
ezmaass's Avatar
Have you tried posted in the M5 section? While the M5 is a close relative of the rest of the line-up, I wonder if this is something the folks on that board may have experience with? Either way, it seems to me there's a problem with your cooling system - whether water pump, radiator, etc - and BMW should be able to easily diagnose and fix the problem.
      04-03-2014, 12:18 PM   #15
tven99
GOVNER
I finally had it fixed, they replaced the water pump and it seems to be fine at the moment. But due to my luck i have to change my front two tires, i have a bulge. Thanks for the support everyone.
