2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Painting Calipers
      08-31-2016, 02:40 AM   #1
JOHNBMWM5
JOHNBMWM5's Avatar
Drives: 2022 LCI Marina Bay Blue/ Smok
Painting Calipers
Anyone painted there brake Calipers?, if so what did you use, thanks.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      08-31-2016, 02:59 AM   #2
2011BMW550i07
2011BMW550i07's Avatar
Drives: 2011 BMW 550i
VHT Blue Paint. You want to clean them, sand them down a little and get them rough and then clean and paint.
      08-31-2016, 05:02 AM   #3
JOHNBMWM5
JOHNBMWM5's Avatar
Many thanks.
      08-31-2016, 09:01 AM   #4
PJinCA
USAF Pararescue Veteran
Drives: F10 535
I went with the G2 paint kit, got it on Amazon. I like the brush on kit only because it's more user friendly than sprays.
      08-31-2016, 09:29 AM   #5
JOHNBMWM5
JOHNBMWM5's Avatar
I have looked at this pack, does the paint smooth out?.
      08-31-2016, 09:35 AM   #6
PJinCA
Drives: F10 535
it probably wouldn't if you use the cheap brush that comes with the kit. instead I get 1" foam brushes from home Depot (0.67 cents each) and use that, it makes for a smoother finish. no brush strokes.
      08-31-2016, 10:17 AM   #7
maxximus
maxximus's Avatar
Drives: 535i xdrive
I just did it this weekend: http://f10.5post.com/forums/showthread.php?t=1299493
I put some pics of where I taped off and the paint I used.
      08-31-2016, 12:23 PM   #8
M5Beast_NYC
Drives: 15 M5
G2 paint kits are pretty good but pricey. Ive used high temp spray paints on a few of my cars over the years and held up very well. i usually slap on a high temp clear coat on it as well for easy cleaning and less of stain on the actual color.
      08-31-2016, 12:27 PM   #9
JOHNBMWM5
JOHNBMWM5's Avatar
Many thanks for all the replies.
      08-31-2016, 01:54 PM   #10
TTG
TTG's Avatar
Drives: M340
You kept it very classy which is exactly what I am planning on doing.
Did you have any problem with the clear coat? In the past whenever I appy clear, it would totally wrinkle and mess up the base coat.
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
      08-31-2016, 03:11 PM   #11
PJinCA
Drives: F10 535
If the clear wrinkles itt usually means it is a different type of paint than the base coat. For example: enamel doesn't play well with acrylic paints. For brakes, which are normally high temp enamel paints, it's best to use something like high temp engine enamel clear. Do not wait more than 15 minutes between coats, otherwise you have to wait up to a week for the paint to fully cure before you can put on the clear. Make sure the temperature is within the range indicated as well.
Basically, follow the instructions on the can
      08-31-2016, 03:41 PM   #12
maxximus
maxximus's Avatar
Drives: 535i xdrive
Did you have any problem with the clear coat? In the past whenever I apply clear, it would totally wrinkle and mess up the base coat.
No problems yet..that I've noticed. I will keep an eye on it each day though and report back if anything goes weird.
I really didn't even need it. I could have skipped the clear entirely and been fine with the black. I personally don't think it "glossed" anything up that much.
