2010 2011 BMW 5 Series Forum F10 M5 exhaust on 550 in Houston area? |
01-17-2014, 09:40 PM | #1 |
Rep 672
Just sourced a M5 exhaust but want to hear it person first before I install it. Anyone in the Houston area have this on their 550?
01-18-2014, 09:27 AM | #3 | |
Rep 2,080
I have the M5 mufflers and then removed the oem 550 center muffler w/ a custom x-pipe, making the setup identical to the m5 full exhaust except the 550's is 2.75" vs. the full 3" in the M5....but the diff in diameter doesn't affect sound too much. Here's a shitty video... i am waiting for better weather for a proper video and write up of the x-pipe |
01-18-2014, 11:02 AM | #4 |
Rep 318
Sounds great!! I'm thinking about doing the same...did you use a pre fab x pipe for the center muffler replacement or did the shop make one on the fly? Do you have a pic of the x pipe installed?
Thanks |
01-18-2014, 01:39 PM | #5 | |
Rep 2,080
https://www.dropbox.com/s/ie63mmmxrp...%2004%20PM.jpg" rel="" target="_blank">http://<a href="https://www.dropbox....4%20PM.jpg</a> https://www.dropbox.com/s/v8p9gq40o9...%2026%20PM.jpg" rel="" target="_blank">http://<a href="https://www.dropbox....6%20PM.jpg</a> |
01-18-2014, 02:14 PM | #7 |
Rep 672
I've got the whole system, but thinking of just putting on the mufflers. I don't want too much sound, and defintitely no drone. I'd like to keep it as stock sounding as possible unless I'm getting on it a little bit. Do you think this is possible with the OEM setup?
01-18-2014, 02:50 PM | #8 | |
Rep 672
01-18-2014, 07:50 PM | #9 |
Rep 197
They come with the factory valves, and there's no drone - I have just the mufflers. But I'd connect the entire exhaust if I had it. I wouldn't mind a little more note - actually looking to either remove the middle muffler or resonator
01-18-2014, 09:17 PM | #10 | |
Rep 2,080
I'll post clips together for just m5 mufflers and then with the added x pipe. |
01-18-2014, 09:19 PM | #11 | ||
Rep 2,080
Then, adding the x-pipe replacing the center muffler makes the overall setup identical to the full m5 setup minus the 0.25" difference in diameter and the fact that the m5 oem has no crushed points. Last edited by scott135i; 01-19-2014 at 04:38 PM.. |
01-20-2014, 02:04 PM | #12 | |
Rep 672
01-20-2014, 09:10 PM | #15 | |
Rep 2,080
http://f10.5post.com/forums/showthread.php?t=903100 One video below is indoors and one is outdoors so not the ideal apples to apples comparison but still... M5 Mufflers only video: M5 Mufflers and Xpipe replacing center muffler: |
01-21-2014, 06:39 AM | #16 |
Rep 672
[QUOTE=scott135i;15305017]Just M5 mufflers is still pretty darn quiet. I have 0 drone with M5 mufflers and the center muffler cut out. I was running M5 mufflers only for 1.5 months but wanted more sound... here is my original writeup:
http://f10.5post.com/forums/showthread.php?t=903100 That honestly sounds exactly like what I'm looking for. A nice factory sounding setup with no drone, a little louder than stock. Thanks for sharing. |
01-21-2014, 09:08 AM | #17 | |
Rep 2,080
[QUOTE=Mbbrewer;15306444]
01-21-2014, 09:53 PM | #19 |
Rep 2,080
I was about to but heard the chance of drone on the highway is much greater. It would probably be minimal drone, but it would be there. It'll definitely sound better with them removed....
01-22-2014, 01:04 AM | #20 | |
Rep 318
Hi Scott, Can't seem to get drop box to work for me...could you kindly post the pic of your x pipe another way? Thanks, HDEddie
01-22-2014, 07:12 AM | #21 |
Rep 2,080
Here you are
01-22-2014, 11:37 AM | #22 |
Rep 318
Very Nice! Thanks for all your efforts posting your great mod. I'm sure when some of us do our M5 muffler mod, your "pictures will be worth 1000 words" at the muffler shop.
