2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 550i Exhaust Tips Closed
      10-18-2010, 03:52 PM   #1
ksh8759
ksh8759's Avatar
Drives: BMW 2013 E92 M3 coupe
I have 550i and I just have found that two out of four exhaust tips are closed. I have talked with engineer and said it automatically opens when rpm goes high, so I tested it and it did not opened.
Does anyone know why those are closed and can it be open? Will it make any sound better?
(sorry for poor english)
      10-18-2010, 05:09 PM   #2
marcielago
marcielago's Avatar
United Arab Emirates
12
Drives: SG F10 550i MSport, CB E39 M5
Normally they do open after a certain speed or RPM. I have a friend who have actually seen it happen in front of his eyes on a 750 il. Give it another re-check and if it still doesn't open then you should take it to service.
Maybe it opens on higher speeds than you have actually checked... just speculating
      10-18-2010, 05:37 PM   #3
JOHNBMWM5
JOHNBMWM5's Avatar
Drives: 2022 LCI Marina Bay Blue/ Smok
Probably works the same as the RS4's with a vacuum pipe, just blank it off and it will stay open.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      10-18-2010, 06:22 PM   #4
kscarrol
kscarrol's Avatar
Drives: 2021 X3 M40i, 1974 2002 Tii
Don't rush to lock the valve open. I'll have to try and dig around but we had a similar valve on the E60 550 and I recall some folks locked it open and they were no pleased with the exhaust note at lower rpm's.
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual
BMWCCA # 327475
      10-18-2010, 10:05 PM   #5
ACZakka325i
ACZakka325i's Avatar
277
Drives: 2 stroke
If you are starting a cold motor, it may be staying closed as to heat up the cats. Once warm it will prob open with higher rpm.
(Waitlist): #1 M2CSL
(Current): 2016 F15 X5 3.5xdrive - 2010 997.2 C4S Coupe
(Past): 2016 F30 340xi M-Sport -2013 535i xdrive
2008 E92 M3 - 2006 E90 325i
2002 E46 325xi - 1991 E30 325i
      10-19-2010, 03:58 AM   #6
HighlandPete
Drives: BMW F11 535i Touring
I wouldn't panic either, the operation will depend on the management strategy. Could be much more complex than previous models, so we may need to learn a bit more of the function.
HighlandPete
      10-19-2010, 12:05 PM   #7
E60orBust
Drives: "The Brothers //M-Sport" E90/2
In the past, NA engines closed one port to increase backpressure and in-turn, low end torque. Well these FI engines have gobs of torque at the low end already.
5'series vac tube works in reverse as a 3'series. A 3'er will suck it shut at low speeds and release at high speed (MPH, not engine load). A 5'er will 'suck it open' at high speed, so disconnecting that vac line won't do a damn thing but keep it shut full time.
That's why I used 2 zip ties per side to strap that hole open . Exhaust tone is a bit more aggressive than stock at low speeds and take off, or as aggressive as you are going to get with the factory resonators, bigass H pipe and TUV Exhaust mufflers
Down for Maintenance
      08-30-2011, 12:35 PM   #8
coolhandshin
South Korea
16
Drives: '08 528i, '11 650i Conv.
anyone by any chance try the 'golf tee mod' or 'ball bearing mod' or disconnecting the connector to the actuator mod on a 5 series?
Is it really true disconnecting it won't simply one the flap valve on a 5 series?
      08-31-2011, 11:24 AM   #9
Loni5z
Loni5z
Drives: 2013 Frozen Red E92 M3
It opens under full throttle and stays open alittle bit after that. Its closed most of the time to keep to smog level restrictions I spoke to a experienced worker in the service department about that
      02-24-2012, 11:46 AM   #10
s2kdagjd
s2kdagjd's Avatar
45
Drives: G05 M50i
can you give us some more detailed feedback on how you got the flaps to stay open all the time? thanks!
      02-24-2012, 06:08 PM   #11
s2kdagjd
s2kdagjd's Avatar
45
Drives: G05 M50i
anyone have a DIY on this???
      02-26-2012, 12:04 PM   #12
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
The exhaust actuators open the secondary exhaust valves during high load. You will not be able to see the valves open when sitting still, revving the engine. There's not enough engine load, to generate sufficient vacuum to pull the actuator valves' diaphragm.
You can check if they really open, by seeing carbon build up on the exhaust tip. My E70 35i has the same setup.
      02-28-2012, 06:27 PM   #13
ben_ben125
ben_ben125's Avatar
Drives: G37s, 550i ,
any \diy on this?
      03-01-2012, 03:48 PM   #14
Jmo550
Drives: 15' X5
zipties my friend
2015 BLK/BLK X5 35i - M sport
997.1 GT3
      03-01-2012, 10:13 PM   #15
ben_ben125
ben_ben125's Avatar
i did it and found no difference ...
