2010 2011 BMW 5 Series Forum F10 BMW F10 Coding DIY (and other Fxx models) |
07-12-2016, 01:06 AM | #133 |
Rep 40,907
Drives: 2018 Alpina B6 650ix GC
You are in CAS module. iDrive Disclaimer is in your Head Unit module (e.g. HU_xxx).
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
07-12-2016, 07:25 PM | #134 | |
Rep 7
I did edit it and it worked perfect. I activated LDW but it doesn't even come up as active on a dashboard. I can see there's a camera on the windscreen. |
07-12-2016, 07:41 PM | #135 | |
Rep 40,907
Does car have the minimum hardware for LDW, as in KAFAS Camera?
07-13-2016, 01:48 PM | #136 |
Rep 357
Drives: 19' M2C
dealer
I just got my car back (F10) from the dealer for service and I am trying to edit HU-NBT and I get an error (CAFD_00000DED_003_15_028 Fehler:
File for "cafd_00000ded-003_015_028" not found! [C012]) Did the dealer delete a file, I can edit KOMBI just not HU-HBT. Because it worked before I brought it to the dealer. Has anyone had this problem? Thanks! |
07-13-2016, 01:50 PM | #137 | |
Rep 40,907
07-13-2016, 07:26 PM | #138 |
Rep 357
Drives: 19' M2C
Can some one please remind they way to program for the volume being displayed on idrive when you change it?
Thanks |
07-13-2016, 07:59 PM | #139 |
Rep 40,907
HU_NBT => VOLUME_POPUP_DISPLAY = aktiv
NV GUNS57.50 |
07-13-2016, 08:05 PM | #141 |
Rep 357
Drives: 19' M2C
07-14-2016, 08:59 AM | #143 |
Rep 40,907
PM sent.
07-14-2016, 09:55 AM | #144 |
Rep 35
Drives: 2013 528i
What battery charger do you guys recommend in the under $150 range ?
07-15-2016, 07:16 AM | #147 | |
Rep 40,907
It is capable of only 1.25 Amps. It may be fine for Coding, for those who do not want to run their motors, but in no way is it fine for Programming (Flashing), where you really need at least 50.0 Amps.
07-15-2016, 08:36 AM | #148 | |
Rep 35
Drives: 2013 528i
Yes, I am looking at flashing, most of the 30A+ i've seen are in the $350 plus range.
I might just rent one for the weekend. Quote:
07-15-2016, 09:41 AM | #149 |
Rep 40,907
You can always just Jump car being programmed to the running motor of another car. All it costs is a few gallons of gas.
07-16-2016, 11:26 AM | #150 |
Rep 35
Drives: 2013 528i
...and that is how I did it. Thanks for the tip.
So this morning I flashed HU_NBT (from 13-03 to 16-07) with no issues, took about 30 mins. Th flash updated the Media and Telephone version from 1.x.x to 3..x.x I also flashed the KOMBI, and HU that took about 5 mins but left me with a check engine light on. Can E-SYS read the error code? I read in some thread that this could be expected, just clear and it should not return. Thanks. |
07-16-2016, 11:30 AM | #151 | |
Rep 40,907
With E-Sys: Click "External Applications" in the left menu. Click "External Application" Double-click "Transmitter" Scroll to the bottom and click "14 FF FF FF,31 01 0F 06,31 01 40 00 00,31 01 40 00 05,31 01 40 00 01;Clear all DTCs (clear DTC,clear Infospeicher,ZFS – DM_Lock,clear ZFS – DM_Clear,ZFS – DM_Unlock)" Click Connect Click Send
07-17-2016, 08:51 AM | #152 | |
Rep 35
Drives: 2013 528i
Turns out it was not needed, I started the car right after the last update and the engine light was on. Drove to the gas station and stopped the engine while refueling and it didn't come back after starting it.
Thanks again for all the guidance. Quote:
07-21-2016, 10:29 AM | #154 |
Rep 35
Drives: 2013 528i
Can anyone provide a link to the most recent GRACENOTE database?
Thanks -- Carlos |
