2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Steering wheel does not lock itself
      02-03-2011, 07:47 AM   #1
tetiker
Drives: 2014 Porsche 911S
Exclamation Steering wheel does not lock itself
Hi,
today I realise that my car's steering wheel does not lock itself after turning car off.My all previous cars' steering wheel lock itself after turning ignition off.I can turn to the left or right to the utmost if I force enough. I call my dealer and he says new f10 does not have this feature due to EPS.
How about your steering wheels?
      02-03-2011, 08:26 AM   #2
stevelup
Drives: 520d F10 with lots of toys
Mine locks as soon as I open the door.
      02-03-2011, 08:56 AM   #3
tetiker
R u sure?
Because, It is diffucult to turn the steering wheel on the asphalt.
But on the ice it is too easy.I understand it does not lock on the ice
      02-03-2011, 09:05 AM   #4
tetiker
I call my dealer and he says f10 just locks the transmission. The steering wheel does not lock itself.I am gonna try it on a new car at showroom
      02-03-2011, 09:08 AM   #5
gorban
Sweden
11
Drives: F11 520xdAT, E87 120dM
I would guess that with modern electronic protection systems where you can't highwire the car, a steering lock doesn't make sense.
      02-04-2011, 09:44 AM   #6
stevelup
It may or may not make sense but mine definitely has one!
As soon as you open the door, you can hear an actuator behind the wheel move, and at that point the steering wheel is locked solid.
Maybe this is country specific?
      02-04-2011, 10:13 AM   #7
tetiker
May be.
I talked one of friend from germany and he said his car also doesnt lock.
When you turn ignition off it really becomes too hard to turn the wheel. But if u use enough force u can turn it. I realize it on an ice where it becomes too easy.
      02-04-2011, 05:12 PM   #8
stevelup
I don't want to get into an argument here but I am telling you categorically that my car has a steering lock.
If I stop the engine, nothing happens. The steering of course becomes extremely stiff due to the lack of power assistance but I can still move the wheel.
The second I open the drivers door, there is a mechanical noise from behind the dashboard and from that point onwards, the steering wheel is completely immobile and cannot be moved anything more than a couple of millimetres. Sometimes you can even see the wheel move ever so slightly as the lock engages.
Yours is either faulty, you're not testing it properly, or that feature is not present in cars built for your country.
Have you tried moving the wheel after turning off the ignition and opening the drivers door?
      02-05-2011, 12:58 AM   #9
raleedy
Drives: 2016 228i 6-speed
On the E9X series, at least for the US market, the steering lock was deleted sometime in 2007 after a fault required steering column replacements in a large number of cars. It's possible that such locks are required by law in the UK; that would explain the difference. I would guess that the lock is pretty redundant with all the other immobilization features.
      02-05-2011, 02:43 AM   #10
tetiker
Yes. It does not lock.Here, new 5 and 7 series steering wheels dont lock
      02-05-2011, 02:50 AM   #11
stevelup
Must be a regional thing then
      02-05-2011, 06:38 AM   #12
finbrad
Drives: F10 520D
Stevelup- are you sure it is actually locking
      02-05-2011, 11:58 AM   #13
DuneMan
Drives: 2011 535i, Sophisto Gray
LOL!
      02-05-2011, 03:05 PM   #14
Titanflux
Titanflux's Avatar
Drives: 2010 E90 335d M Sport auto
It may only feel like it's locked once you've turned it a fair bit? That's what I would expect.
G32 640i xDrive M Sport GT with Driving Assistant Plus
      02-06-2011, 08:38 AM   #15
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Interesting, I wonder if this is more to do with the build date rather than country of registration.
My September built, UK purchased and registered F10 535d M Sport most definitely does not have a steering lock; yes, of course the wheel turning resistance increases when you switch off, but at no point does it lock, even with the ignition switched off (second button press after stopping the engine). I also locked myself into the car and, again, no steering lock.
