2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Marketplace Commercial Marketplace - F10/F11 Classifieds Supreme Power | KW Suspension V1, V2, V3 ***BEST PRICING!***
      08-13-2018, 06:10 PM   #1
matt@supremepower
matt@supremepower's Avatar
KW Variant 1: Part #
1022000X
[/center]
The Variant 1 is KW's basic simple and effective coil over kit that is still packed with lots of features -
Pre-set damping optimized for a blend of ride comfort and handling with less bodyroll than the standard suspension,
Stainless steel strut/shock bodies and composite spring perches for superior corrossion resistance,
Individually height-adjustable - Front = 25-50mm lowering; Rear = 30-55mm lowering,
TUV approved lowering range and operation,
Expert engineering and design for ease-of-use and long durability,
This is the ideal coil over kit for a F30 owner who does not plan on tracking or autocrossing the car and just wants a lower, more aggressive stance and better handling. KW has set the shock damping rates to be an excellent balance for a smooth yet taut ride, and to resist bodyroll motions for better handling. The Variant 1 differs from the Street Comfort set in that it has stiffer springs and revised shock settings. If you want a sportier ride and better handling than stock the Variant 1 is an excellent choice.
Coil over suspensions are better engineered suspension options compared to a standard shock + spring package. Since the springs and shocks in a coil over are designed by a team of engineers to work together, there is much better suspension travel and more precisely tuned specifications for spring and shock rates. Using separate shock and spring specs may result in premature coil bind or shock bottoming. And most coil over kits offer more features than the traditional packages. Coil overs are also more useful when larger wheels/tires are used because you can precisely set the ride heights to clear the new tires.
Fitment Note: Wheel spacers may be required depending on wheel/tire sizing and ride height setting.
Cars with the factory EDC electronic adjustable shocks must have the system disabled with the optional KW EDC Cancellation Kit (or similar). This is a direct fit for cars without EDC.
KW Variant 2: Part # 1522000-335
The KW Variant 2 gives shock rebound control to give you more options in fine-tuning the handling of the car. The V2 includes the same features of the V1 kit, including -
Adjustable Rebound with fixed compression settings - optimal ride comfort then dial in more grip and a better balance with less bodyroll than the standard suspension,
This kit is an excellent compromise between a fully-adjustable V3 suspension and the basic V1 street kit. It's great for someone who does not want to make complicated and time-consuming shock adjustments. Just dial in the rebound for more grip and less body motions. Set it back for a compliant street ride.
KW Variant 3: Part #3522000R
Want full control? The KW V3 gives you multiple settings for both rebound and compression. You have full access over ride comfort and handling to dial in that perfect setup. Race teams rely on adjustments to get that perfect lap time and having shock controls at your fingertips is key. KW V3 features -
Separate adjustments for compression (14 positions) and rebound (infinite settings),
Stiffer springs over stock for less bodyroll than the standard suspension,
Whether you track the car often or only use it for backroad carving the V3 will give you the tools to set up an ideal handling condition. You can crank it up for smooth and fast surfaces or soften it for city or rough roads. Since each shock is 2-way adjustable you can alter the front-rear balance to account for brake dive or squat during power application coming out of the corner. You are in total control!
Ordering:
Give us a call or PM to setup an order.
Mounting & Balancing:
Expect perfection: All orders include complimentary mounting and balancing on our Corghi Artigulo 50 Touchless Mounter and Hunter Engineering 9700 Road Force Balancer
Shipping:
Perfect tire and wheel packages delivered consistently. All wheel and tire packages are boxed and handled with care. No stapping. No cardboard on faces. Extra Heavy Duty Boxes surround your purchase and ensure delivery to your door in perfect condition. No cutting corners here.
Phone:
You may call us at 714-632-1951 to place your order over the phone.
Payment:
Credit/Debit Cards: Visa, Mastercard, Discover, Amercan Express. (avail online & over phone)
Other Payments:
Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods.
Shipping:
All orders will be shipping via Fedex. If you are interested in shipping to Hawaii, Alaska, Puerto Rico and Canada, please call us. You will be charged additional shipping fees. International shipping is available at reasonable prices, please contact us for shipping quotes.
Hours of Operations:
Monday - Friday from 9AM to 6PM PST
Saturday by Appointment
Sundays we are closed
Retail Showroom and Installation Center:
Come check out our 10000 square foot facility in Fullerton, CA. We install everything we sell.
Contact Info:
Phone: 714-632-1951
Email: matt@supremepower.com
Website: http://www.supremepower.com
If you have any questions, please feel free to PM, email or call us anytime and we will do our best to get you the info you are needing!
      09-18-2018, 12:54 PM   #2
matt@supremepower
      09-28-2018, 07:03 PM   #3
matt@supremepower
