2010 2011 BMW 5 Series Forum F10 N55 Behind the Grill Intake DIY |
07-19-2021, 08:50 PM | #89 | |
Rep 505
Drives: 2013 BMW F10 N55 535i XDrive
Outta those 3 cars... the Kia is the one who wanted to play??
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
07-19-2021, 08:59 PM | #90 | ||
Rep 1,442
Drives: 2011 535i 6MT
07-19-2021, 09:02 PM | #91 |
Rep 505
Just seen a few around... never seen anyone pushing one, heard the got some pep to em'... good thing I'm not stock.. would love to hit it with one of them
07-20-2021, 11:06 AM | #92 |
Rep 1,442
4.4 0-60, 12.9 1/4 mile - not bad stock - but it's still a KIA.
07-20-2021, 02:09 PM | #93 |
Rep 662
I actually test drove one a month ago. A 2021 facelifted/ updated Stinger GT. That mofo moves! And the interior is gorgeous. BMS has their JB4 to it and gets great power out of it. Do not underestimate them folks! No challenge for a tuned PS2 F10 but stock turbo could be fairly matched or even outgunned depending on mods
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
07-20-2021, 04:16 PM | #94 |
Rep 1,442
Just got word from DS and he said that the codes I got are a GOOD SIGN. He said he can adjust things so that the CAI doesn't ram too much air into the cylinders (which is where this code is from) by adjusting the throttle plate (pulling it back) but what that means is on the top end he'll be able to get more boost out of things as long as I can get the fuel there... so things are looking up as far as the behind the grill intake being an actual viable upgrade and a product I might be able to get out there to the community. Here you can see that at about 3500 RPMS even though I had the pedal smashed it was starting to close the throttle plate because it was getting TOO MUCH AIR... all good things!
95blkmax212.50 |
07-21-2021, 08:19 AM | #95 | |
Rep 662
Now that this has been proven to outflow the traditional intakes, this brings up another question/ issue. Would this setup REQUIRE a custom tune, OR can the DME keep it all under control? I know it's different with your car being PS2 and pushing that much more air than a stock turbo. Perhaps another kit should be made for a stock turbo community member to test (if you don't have one locally, I volunteer as guinea pig! )
07-21-2021, 07:06 PM | #96 | |
Rep 1,230
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
07-22-2021, 06:08 PM | #97 | |
Rep 1,442
I think we'll need someone to test it out with a stock turbo. It's possible with a stock turbo that it couldn't push more air than what the engine could handle...? only one way to find out... |
95blkmax212.50 |
07-22-2021, 09:54 PM | #98 |
Rep 662
I'd buy a kit from you if you make an additional one, or shoot me that parts list and I can fab it up myself and get this testing under way
07-24-2021, 01:17 PM | #99 |
Rep 2,591
I am now deathly curious as to how the MST intake measures against this custom one.
2015 BMW 535xi
07-24-2021, 01:57 PM | #100 | |
Rep 662
I'd be more than happy to do a before and after dyno on this intake setup once I can get some parts rolling in
07-26-2021, 10:49 AM | #101 |
Rep 518
I went through this with my attempt to put the intake behind the grille and worked with DS. Here are some areas to check to avoid difficult to solve errors.
- smoke test and cure all leaks - check for unmetered air after maf - ensure your TMAPs are in working order(air plausibility errors can be checked by swapping tmaps atmospheric with charge pipe) - of course the tune itself - custom wiring harness, gauge of wires is oem and voltage is correct
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
BimmerHausPerformance514.00 95blkmax212.50 |
07-26-2021, 10:53 AM | #102 | |
Rep 1,442
07-26-2021, 11:30 AM | #103 | ||
Rep 518
https://www.fcpeuro.com/products/bmw...ng-18307553601
BimmerHausPerformance514.00 |
07-26-2021, 11:33 AM | #104 | |||
Rep 1,442
07-26-2021, 11:35 AM | #105 | ||||
Rep 518
07-27-2021, 05:58 PM | #106 |
Rep 1,230
I actually had mine set to 9. I used the gauge as a reference to see when the flap fully closes and Pure also recommeded me for 9 after adjustment.
N55 GENERAL
01-17-2022, 06:51 PM | #109 |
Rep 1,442
We are still working on the final tune… just about done. I was able to hit 21lbs of boost at around 6k rpm with a wgdc of only 45-55%.
Once I am done with this round (pump gas tune) I'll be starting the e85 and meth tune. Shooting for 600whp. |
01-18-2022, 03:25 PM | #110 |
Rep 1,442
Here is a log I just pulled. I actually got to play with a unicorn when I went out to get this, v10 m6... it couldn't keep up lol. That was fun.
Anyway, DS hasn't yet opened up the WGDC on this to make it hit full boost up top, that'll be his next adjustment however this does give you some solid data as it relates to the intake. You'll also notice quite a bit of oscillation between 3500 and 5500 RPM's but none the less you can still see some #'s there, we are still smoothing that out in the tune. There isn't much point in logging this high of RPM because to stay in the power band I'd be shifting at about 6200 or so, and the turbo starts to fall off up top but none the less here it is. 4th gear @ 7k rpms is like 140MPH so yea, no thanks. Breakdown of a 4th gear pull (manual transmission): 3k: 18.0lbs 50% WGDC 4k: 19.1lbs 42.4% (Average between two data points) 5k: 18.1lbs 63% WGDC 6k: 19.3lbs 54.9% WGDC 6.5k: 17.1lbs 52.4 WGDC I took the average of my boost and WGDC from 3k to 6500 and it worked out to be 18.8 Lbs of Boost at 51% WGDC. https://datazap.me/u/browbmw/rev-58-...5-19-30&solo=4 Last edited by BimmerHausPerformance; 01-18-2022 at 03:38 PM.. |
