2010 2011 BMW 5 Series Forum F10 N55 Behind the Grill Intake DIY |
02-10-2022, 10:11 AM | #133 |
Rep 2,591
No branding as far as I can see, but it appears to use the same seal material as the male BMW plug. There is a small tab (circled area) that is used to secure the housing to the plug. As you can see, it's a bit too thick by maybe a hair, requiring you to push in quite hard to get it to engage. When you do that, because there is no clip on the other side, it introduces a slight angle. Not a big deal, just requires a razor blade and some scrapping to thin out the tab by a tiny bit.
I went searching for these since I'm trying to build a budget MST intake. We'll see how that goes. Does anyone know the ID of the tube where the MAF sits?
2015 BMW 535xi
02-10-2022, 11:20 AM | #134 |
Rep 1,442
Drives: 2011 535i 6MT
I have a guy putting together my extension at 44 inches long with BMW connectors built and shipped for less than what that guy is selling just the connections for. I have to buy in bulk, so if you need one, it'll be in my kit, or DM me.
02-10-2022, 09:50 PM | #135 | |
Rep 5
BimmerHausPerformance514.00 |
02-10-2022, 11:28 PM | #136 |
Rep 518
Nice work BrowBMW ! Sending the Helix back and moving to a Walbro 450. I'll move the intake back to the front with that MST and have to hit up D Shoup.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
02-10-2022, 11:30 PM | #137 | |
Rep 1,442
You don't want to go behind the grill with mine? Maybe we could do a trade for the helix…! |
03-06-2022, 05:10 PM | #138 |
Rep 1,442
First 3 orders going out. Inlet all the way to behind the grill is 650. Includes heat shield, all adapters etc. Doing an install video. I just got done doing the harness for the 3 orders.
03-06-2022, 09:47 PM | #139 |
Rep 668
yeeeeeaa boiii!! Cant wait!
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
03-07-2022, 02:02 PM | #141 |
Rep 1,442
The high flow inlets are on back order so I can start shipping as soon as those are available again. It is possible you could get messages for too much boost if you don't run a tune so that would be up to you!
03-07-2022, 02:25 PM | #142 |
Rep 234
Think the mst intake would cause the same overboost condition? It's routed in a similar fashion I just don't know how it gets air from the front as the intake inlets are on the opposite side..
Thanks |
03-07-2022, 02:34 PM | #143 | |
Rep 1,442
That will not happen with an MST intake as it does not include the high flow inlet and is still just sucking air like any other intake on the market. If you run this intake without a tune you might see an error like this: |
06-08-2023, 09:24 PM | #145 |
Rep 1
where can I buy this for f10 n55 535?
06-08-2023, 09:30 PM | #146 |
Rep 1,442
Hit me up if you need anything.
Insta: BimmerHausPerformance Dlepper@bimmerhauseperformance.co Www.BimmerHausPerformance.co 303-944-2502 |
