2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Marketplace Owner's Marketplace - F10/F11 Classifieds Musicar 10" Fiberglass Subwoofer Trunk Enclosure
      01-18-2024, 05:04 PM   #1
jlskip
Drives: 2014 BMW 550IX
USD 350.00
Or Best Offer
Musicar 10" Fiberglass Subwoofer Enclosure for passenger side trunk.
Came out of my 2014 550IX. Had a JL Audio 10W6V3 in it previously, which is pretty deep.
Secures under factory hook location. Comes with molex wire connection so you can quick disconnect and take out if needed.
Shipping is not included. It is probably around 10 LBS.
Lower 48 states only.
Triple-Thickness fiberglass walls – three times thicker than any other enclosure
The “OE-Look” upholstery has been hand-dyed to match your BMW trunk
As a Musicar design element, the woofer is recessed from the outer edge
***Application Notes***
This enclosure does not fit the F10 5-Series HYBRID
It is prewired with 16/4 jacketed and insulated speaker wire. Unless otherwise requested, it will be wired for a single voice coil with dual 16-gauge leads, for a functional 12-gauge capability.
This enclosure is validated to fit these drivers:
JL 10W1 v3
JL 10W3 v3
JL 10W6 v3 D2
Audiofrog G10
Audiofrog GS10*
Arc Audio Arc Series 10 (no grille solution off the shelf)
Morel Ultimo SC10
Image Dynamics ID10v3 (no grille solution off the shelf)
The following woofers do NOT fit:
JL Audio 10W7
JL Audio 10TW1
JL Audio 10TW3
Image Dynamics IDQ10v3
Image Dynamics IDMAX
https://musicarcertified.com/product...sure-preorder/
