2010 2011 BMW 5 Series Forum F10 JB4 Beta and Error Codes |
02-03-2017, 02:17 PM | #1 |
Rep 14
Hey guys. I just installed a JB4 Beta, JB4 Connect, and a BCM on a 2011 BMW 550i. I only installed the BCM in case I want to have it in the future. Today I would be thrilled with Map 1 or 2.
Actually, right now I would be happy with no codes on Map 0. Does anyone have any suggestions as to what the issue could be or what I need to do to clear a Rail Sensor Code? After I got it all hooked up, I started it and it immediately threw this code, along with "unspecified code". It was running perfectly before the install. I went back and double and triple checked all connections and I can't figure out what the issue is. Anyone have any idea where I should start? Thanks so much for the help. Long time lurker, first time poster. |
02-03-2017, 02:23 PM | #2 |
Rep 14
Sorry..... 119001 Rail Sensor Short and 119101 No Description Found
Those are the exact codes its thrown since I first fired it up. |
02-03-2017, 03:16 PM | #4 |
Rep 14
Thanks for the reply
My concern was that if there was an issue with something (and I caused the short in the rail sensor), then wouldn't whatever caused the issue still be there to cause a new one to short when I fire it up after replacing it? The car had no issues before....never in limp mode once.... the second I fired it up it fired off the code.
I just didn't know if there was a setting in the JB4 connect app or some common error somewhere along the line that can cause this. I bought the JB4 Beta used and set everything back to default, then fired it up in Map 1. Thanks for the help... I'm dying to get this thing out and see what it will do. |
