05-09-2017, 11:58 PM | #23 | |
Rep 659
05-09-2017, 11:59 PM | #24 | |
Rep 659
07-26-2017, 06:06 PM | #25 |
Rep 30
JB4
S1ammin,
I just ordered my JB4 today. I ordered it from **********s. It is great getting some useful tips for the install from you guys. I am surprised that BMS has not made upgrades and added hardware for safer installation. I also ordered the Bluetooth option so I can monitor data from my iPhone. Can't wait to for it to arrive so I can install it. I don't have plans yet for the charge pipe or down pipe. I don't want any red flags for the dealership. What charge pipe did you go with? How does your car sound now with the added power? I have the M Sport exhaust on my car so I am wondering if it will give it more bark and sound better?
2014 BMW 535i X Drive M Sport
Carbon fiber Performance rear deck lid, Carbon Fiber Mirrors, Carbon fiber front bumper spoiler, M Performance exhaust and 20" M5 343M wheels with MPSS tires |
07-26-2017, 06:48 PM | #26 |
Rep 194
The only mods I have are the JB4, BMS intake and SprintBooster. I've read a few different places that the 535 charge pipe doesn't have the hard angle like the CP on the 335 and do not seem to be prone to blowing up.
As far as sound, I really can't say I can notice a difference with the JB4 enabled vs. disabled (map0 or 4=disabled). The install is pretty easy although I cheated a little. I didn't connect the Flex Fuel connection since I don't have access to flex fuel and also, I located the JB4 in the engine bay and just lying on top of the big intake tube. It's pretty secure there and makes for easy removal if I need to take it off for a dealer visit. The only connection that was reasonable difficult was the PWG connection. Your car may be EWG so I don't know if it is as difficult to get your hands in there but on this car, it was a PITA. Also, running the CANBUS wire thru the firewall will require a coat hangar but it wasn't too bad. Just be sure to disconnect the battery as instructed. I've read several times where someone didn't and wound up hosing their DME! You're gonna love that extra power man. Makes the car feel so much lighter! |
07-28-2017, 07:39 PM | #27 |
Rep 30
JB4
Ok, had my mechanic install mine today. Install went pretty straight forward however he did not install the OBD cable that came with it. He said I shouldn't need to connect it to make it work. I didn't receive the bluetooth module yet so he said he could install BT when it arrived and then connect the OBD cable if I preferred to.
First few runs felt like the car was making great power and appeared to be very noticeable difference. Upon return to the shop I shut the car off and restarted it. At this time I noticed a "check engine light". He cleared the codes and I ran it again. Car made good power and seemed to be running great. Same thing, after shut down and restart the light came on again. He connected his $11K BMW scan tool and these codes came up; 1BC112 Zero=gear sensor, electrical: short circuit to B+ 101F02 Intake pipe absolute pressure, plausibility: Pressure too low 105201 DME: Internal Fault (ambient pressure sensor, plausibility, overrrun: Pressure too high) Can anyone chime in and let me know what they think may be the reason it's triggering the check engine light? The car seems to be running fine and makes good power but the "check engine light is on". I am not going to run it hard and weight for a resolution. I am going to contact BMS and ask them what they believe the problem is? Is it possible that the some or one of the connections are wrong? Maybe he connected them to the wrong plug? The JB4 did not come with installation instructions he used some from the internet but I am not sure if they were for the exact same unit and car. I would think that the plugs would have only work one way. Could they have sent me the wrong JB4 Unit?
Carbon fiber Performance rear deck lid, Carbon Fiber Mirrors, Carbon fiber front bumper spoiler, M Performance exhaust and 20" M5 343M wheels with MPSS tires Last edited by BMW535MSPORT; 07-28-2017 at 07:59 PM.. |
07-28-2017, 11:01 PM | #28 | |
Rep 11
07-29-2017, 02:52 PM | #29 | |
Rep 194
Definitely head over to http://www.n54tech.com/forums/forumdisplay.php?f=16 about those codes. Also, if your mechanic did not connect power to the JB4 like http://www.n54tech.com/forums/showthread.php?t=47317 , you will get a battery drain warning after letting the car sit for a day or two. I've also seen connection instruction for our car floating around that are totally wrong! The guys at n54 will be able to help though. |
08-04-2017, 03:44 PM | #30 | |
Rep 659
08-06-2017, 04:02 PM | #31 |
Rep 14,522
Ah I've been watching this thread since my performance mods now begin. I thought just a simple JB would be fine but whats really the advantage of the JB4 over just the JB? I'll probably have to do some more research like what's the point for data logging? Is there only 2 maps? Do i really need the BT option. Can i just plug the JB4 and call it a day or do you guys really need the option to change maps?
08-07-2017, 10:32 AM | #32 |
Rep 194
JB+ and JB4 are your options. The JB+ is the easiest to install since it just plugs into your TMAP. Two minute install. It essentially runs as MAP1 on a JB4 but I've heard some say that the JB4 on MAP1 has a smoother power delivery. This may be due to the JB4 having more knobs that can tweak different parameters of any given map. Also, JB+ is limited to 3 or 4 psi over stock.
JB4 has several maps plus the ability to create custom maps. The extra maps make it possible for you to get more power, depending on supporting mods, fuel used, etc. The BT option is nice with JB4. You can make all of your adjustments, update firmware and email logs, using the IOS or Android app on your phone. As far as logging, I think if you use JB4 on any map other than map1, you will want logging. Even on map 1, if you are wanting to run some E85 mix, you will want logs to ensure you aren't stressing your fuel pumps and/or leaning out AFR. But, if you are stock and have no plans to ever go catless or any other power mods, the JB+ might be better for you. |
08-08-2017, 03:22 PM | #33 |
Rep 332
There is a TON of wrong info here regarding JB4 install on an F10/535i. Power for the JB4 itself can be done simply by tapping on the the wires in the engine bay (Not to the fuse box) to provide switched 12V power. Second, the BT Module should be using one of the JB4 5V Red Wires from the harness for power, NOT a 12V connection.
There is no direct ECU connection for JB4, everything is done through OBD II, so this is required. The old Positaps method of getting ECU data is no longer supported on any current JB4 firmware. The following thread has plenty of info regarding the install, check out the last 2 pages for the switched wire in the engine bay to use. http://www.n54tech.com/forums/showthread.php?t=47317
2022 G82 M4 - Isle of Man Green w/Kyalami Carbon Bucket Seats - MST Intakes, SSR Downpipes, JB4, AWE Exhaust.
2013 F10 N55 (535i), Pure Stage 2, Fuel-It PI Platinum, Fuel-It Stage 2 LPFP, BootMod3, Custom Turbo Inlet, Custom Cary Jordan Tune, More.. SOLD! 1999 e36 M3 - Estoril Blue - Track Car - S54 Swapped |
09-15-2017, 09:53 AM | #34 | |
IG @bmwF9xG80
3812
Rep 7,592
My buddy with X5 35i, DP, Backend Flash/JB4 just got the "1BC112 Zero Gear Sensor, electrical: Short circuit to positive or open circuit" but hes been running his setup for a few months now. Not sure what made it trigger for him.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
09-15-2017, 06:15 PM | #35 |
Rep 194
Pretty sure that electrical log entry happens when right after you get a battery drain warning. I used to get that when I had my JB4 and BT connected to a non-switched power source.
02-13-2018, 03:54 PM | #36 |
Rep 659
02-13-2018, 05:50 PM | #37 |
Rep 59
The JB4, Bluetooth, and intake are well worth it for the 535i. They transformed my 5 into my own racecar.
Your driving habits will undeniably shift once you can see and hear 15 psi launching you forward. ... local tuners can always give you some dealer tips for a free pizza. OBDII is for logging and I always have it plugged in. You can't even notice the wire when you're looking for it. |
02-22-2018, 07:54 PM | #38 | |
Joint Chiefs of Staff
24083
Rep 190,614
