2010 2011 BMW 5 Series Forum F10 Replaced all eight spark plugs |
07-29-2015, 05:41 PM | #1 |
Rep 249
2011 550i, 54k miles. Rough idle occasionally. Misfires occasionally.
Easy job, I would say 3/10 on difficulty. It took me 45 min total. #1 plug was wet, smelled like gas, injector #1 leaking. #2,#3 wet with what appears to be oily substance on threads, no gas smell. #4-8 all dry. Looking back at my service records, the dealership noted misfires on #1,#5,#7 but only replaced bank 2 injectors (5-8). I took it back multiple times for misfires and rough idle, but dealer couldn't replicate so they wouldn't touch bank 1. I currently have a misfire on #1 cylinder that I'm leaving in, so along with the rest of the info I have will hopefully lead to them paying for #1 injector, and since you can't mix serial numbers, bank 1 entirely. For tools: BMW spark plug socket (12 1 220 etched on side) 3/8" drive ratchet 3/8" extensions totaling ~12" Idle is better, no hiccups, but I'm sure they'll return soon enough with at least #1 injector leaking by. This is just a small bit of info for anyone going through something similar. I think there is already a spark plug DIY somewhere online, but if you have any specific questions about the job just let me know. Worst case, if the dealer won't replace the injector, I will, and that would make a useful DIY.
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
07-29-2015, 05:55 PM | #2 |
Rep 1,300
Nice just paid $500 for plugs and labor to BMW for instance.. All 8 of my plugs were rusted completely!!! Never seen anything like it.
Car drive so much better after.. By misfires are back!! Lol got to change me again. Pics of yours? |
07-29-2015, 06:05 PM | #3 |
Rep 249
Rust, yeah I heard from Serge. Mine have buildup, but I would be hesitant to call it rust. I wonder if E85 mix is the cause?
Plugs were $100 shipped on Amazon, and labor was free. I actually stripped it down to coils removed in under 10 minutes wearing a shirt and tie still. So, it's an easy swap. But you gotta let that thing cool down, I believe the aluminum isn't sleeved with steel threads so you'll pull threads out with the plug potentially if it's still hot. The coil design is very user friendly, piece of cake to take off/put on. |
07-29-2015, 06:24 PM | #4 |
Rep 249
Here are a few pictures, just cylinder #1 and #3. #2 looks like #3, and #4-8 were all dry.
07-29-2015, 08:14 PM | #5 | |
Rep 29
I've had to replace a couple on my old Infiniti, they were not the same for every cylinder. From what I can tell all 8 are the same on the N63. Mike
2011 550i xDrive Tasman Green/Venetian Beige
2001 C5 Z06 Torch Red/Modified Red 1965 Corvette Coupe Glen Green/Black 2001 Infiniti QX4 Black/Black + Rust |
07-29-2015, 08:24 PM | #6 |
Rep 249
I put the same coils back on, I don't believe they are at fault. I was getting misfires, definitely on #1, and if memory serves me correctly #3.
My biggest problem is being that I'm out of warranty I let the misfires go. I mean, I have a BT cable so I can clear the fault, and blah blah blah. I'm quoted at nearly $3000 for the dealership to do the other 4 injectors, and being on salary for the Navy doesn't allow me to throw that kind of cash at my car unless it's absolutely necessary. So, I've lived with it for months. I likely would have continued living with it if I didn't get the strong smell of gas on plug #1 combined with the documentation from before. I plan on wrestling the dealership hard on that one, it's horse crap that they didn't replace all 8 with at least one documented misfire on bank 1. All 8 coils are identical, numbers 1 and 5 are turned the other way, but are interchangeable. So everyone knows: Bank 1 (passenger side) is cylinders 1-4 Bank 2 (driver's side) is cylinders 5-8 #1 and #5 are at front of the engine |
07-29-2015, 09:07 PM | #7 | |
Rep 29
Mike
07-30-2015, 05:42 AM | #9 |
Rep 249
I have had the CCP done, but it only ensured that injectors within the same bank were of the same serial number. I don't remember the CCP evaluating injector performance for replacement.
07-30-2015, 08:09 AM | #10 |
Rep 249
Well, the dealership agreed to go down the path to replace the remaining 4 injectors. They'll need to verify the injector is leaking, but that shouldn't be difficult to establish. My service advisor, who has always been great, said he can get BMWNA to cover the repair, which is a huge relief to me financially. I'd much rather go on a vacation than replace 4 injectors for $3000.
07-30-2015, 09:23 AM | #13 |
Rep 249
PM sent. Also, for anyone else interested in spark plugs, just search for ZR5TPP33 on Amazon, there are several listings and it isn't restricted to the N63's either.
07-30-2015, 09:38 AM | #14 | |
Rep 672
Do you use octane boosters with MMT? My plugs looked like they had a fine layer of rust on them and the dealer said it is from the MMT. |
07-30-2015, 10:40 AM | #15 |
Rep 249
I do, though I likely won't anymore if that is true. That might explain the light reddish coating on all plugs. I would run a bottle through with a tank of gas about once every two months, more for the detergent/cleaning value than any slight octane benefit it may provide.
That's an interesting perspective from the dealer on the rust issue. I wonder if there is anything out there on the web about the effect of MMT on spark plugs.
07-30-2015, 11:38 AM | #16 | |
Rep 672
[u2b][/u2b]
07-31-2015, 03:47 AM | #18 |
Rep 1,407
Oh Shinola. That's grip. Looks like I'm selling/trading mine in for something else after my CPO is up! I replaced the injectors on my n54 and it was easy. I looked at the fuel rail on the n63 and it looks the same. Buy the parts and get an indie shop to do it?
07-31-2015, 10:33 AM | #19 |
Rep 844
Thats my plan... Except right before the CPO is up
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i |
07-31-2015, 11:13 PM | #20 |
Rep 1,407
Very good point my friend... haha... My CPO runs out in May of 2017 so I may look into a 2013-14 CPO M5 when that time comes around. The 5-Series has spoiled me and I can't see myself in another 3- Series unless its an an M-car
08-04-2015, 11:10 AM | #22 | |
Rep 736
