2010 2011 BMW 5 Series Forum F10 Would changing Run flats help quiet the cabin? |
06-06-2016, 11:33 PM | #1 |
///M3 Enthusiast
397
Rep 993
Drives: 05' M3 and 21' Tesla Model 3
Just curious to see if anyone else feels the cabin road noise is bit loud on the highway? Compared to my E500 I had in the past it was a quieter and had a softer ride.
So, is this because of the Goodyear run flats? This is my first car with run flats and I want to know if run flats cause a harsher ride and more road noise? I am thinking about changing them to Michelins. Any feedback would seriously be appreciated. |
06-07-2016, 02:55 AM | #2 |
Rep 14,521
i went from the Dunlop RF's and for me i think it's still the same when i went to regular tires. i will say if you wanna talk about "FEEL" than that's what i can tell you is the difference...much smoother and less vibrations on the steering wheel. the RF's just felt like i was driving on hard bricks at times.
06-07-2016, 06:44 AM | #3 | |
Rep 1,207
The difference between RFT and Non RFT will be higher on 19" than 18". Also, if you have Adaptive Drive or VDC, the difference will be less noticeable. Having said that, I doubt you will see a difference in noise levels. What you will notice is a smoother ride, with the non RFT absorbing a lot of road imperfections.
06-07-2016, 08:53 AM | #4 |
Rep 1,472
Yes, OEM Goodyear tires are horrible in every way possible, comfort, handling, wet traction and road noise. They also get progressively noisier as they wear down. Switching to non run flat tires will result in more comfortable, more precise and quieter ride. Whether that's going to be enough for you, hard to say. I personally have never found F10 cabin to be noisy place, far from it.
06-07-2016, 12:53 PM | #5 |
Rep 697
Drives: 2013 535xi
I switched from the Goodyear OEM all-season run flats to Michelin PSS non-runflats. Tire noise is about the same. The ride and handling are improved.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
06-07-2016, 01:17 PM | #6 |
Rep 36
I also went from the OEM Goodyear runflats to Michelin PSS and, though I don't recall a significant improvement in road noise, everything else got dramatically better. But, I also went from 19" wheels to 18" wheels so I could stop worrying about potholes.
06-07-2016, 11:41 PM | #7 | ||
///M3 Enthusiast
397
Rep 993
My major concern is that I read on other threads that the car's suspension is designed for run flats only... Not sure how valid that is though. |
06-07-2016, 11:43 PM | #8 | |
///M3 Enthusiast
397
Rep 993
I am concerned because I read on other threads the F10 was meant to be run on run flats as opposed to non-run flat tires. Any idea how true that statement is? |
06-08-2016, 07:38 AM | #9 |
Rep 483
Yes it will if you choose a quiet tyre. Noting 2DB difference is almost double. I recently put quiet tyres on mine Michelin. Run flats on F10 is not loud... not sure what is going on with you. Non Runflats will be quieter and ride will be more special.
06-08-2016, 09:02 AM | #10 | |
Rep 15,858
I changed to non run-flats on my E91, kept to the same wheel size. Ride quality improved but standard damping was compromised, was too soft. To get the real BMW feel back to the chassis, changed dampers to improve the body control. Tires on their own may not give you the chassis you are after. But may well be good enough and suit your priorities. On my F11 535i I have Adaptive Drive and 18" RFTs. I've stuck with then and replaced like for like, quieter on the new tires (as is typically the case for most tires). One reason, I run 17" winter RFTs which are a softer ride by comparison to the 18" summer tires. I wouldn't want to be any softer than the 17" RF winter tires. At least with AD or VDC you have a wider working envelope (even on RFTs) and can set the suspension to suit your drive and conditions. |
06-08-2016, 09:24 AM | #11 | |
Rep 15,858
I was discussing this with a tire dealer a while back and they find it is not consistent, a tire with a quiet rating can be just as noisy within the car, as one with a higher noise rating. They find it is more the qualities of the car which absorbs the noise, different tires not always having the desired sound levels. Talking of the F10/11, the guy reckoned I'd hardly tell the difference across the tires available for the car. Not saying there won't be a difference inside the cabin, but not always what we are hoping for. |
06-08-2016, 06:49 PM | #12 | |
///M3 Enthusiast
397
Rep 993
06-08-2016, 07:35 PM | #13 | |
Rep 1,472
06-08-2016, 08:20 PM | #14 | ||
Rep 1,472
Not that this wasn't true for your E91, but that this is too general statement to apply to F10 and all other models as well. Like everything else, it'll depend on the tire you get as replacement. As someone pointed this to me while ago, the only fair test would be to have exactly the same brand and model of tire, one RF and other not. Yes, run flats have firmer sidewalls, but I don't think this makes the ride better in any way, not for me personally on F10. Quote:
Of course he did Seriously though, I'm sure there are some great RF tires to be had, Goodyear just isn't one of them. My winter Dunlops are actually quite good, and they are RF. I have no issues with noise, comfort or harsh ride with those. They are however still wearing quicker than regular tires and are more expensive to buy. And at the end of the day, still may not get me to safety, depending on type of blowout. |
06-08-2016, 08:48 PM | #15 |
Rep 14,521
I will say for me switching to non RF's and my KW's improved the overall ride quality than when I was stock on RF's
06-09-2016, 12:28 AM | #16 | |
///M3 Enthusiast
397
Rep 993
As far as cabin noise I think you are right that I am overthinking the road noise and it may truly just be the sound quality from the speakers in my car. I have the standard speakers and now researching here on the forum about others recommendations. I read Bavauto speakers stage1 was a good upgrade. In any event, thanks for the info and let me know what dunlop tires you are running. I may give that a try. |
06-09-2016, 03:57 AM | #17 | |
Rep 15,858
I totally agree that different tires will have varied performance, ride quality, etc. I'm on Continental Sport Contact 3 SSR, they are good high performance summer tires both in run-flat and non run-flat applications. The SSR won't be as good a ride as the non run-flat, I know that. But how much difference and what value against the negatives, including the run-on-flat capability, without carrying a spare wheel, is all in the calculation to carry on with run-flats, after the issues in the E91. |
06-09-2016, 09:54 AM | #18 | ||
Rep 1,472
You are correct though, sidewall on RF is stiffer, and cars are tuned for RF tires. But for me that does not make them better handling tire in any area no matter the suspension. There’s no universal agreement among BMW owners which is better to use (the whole “no spare” silliness scares many to move away from RF), but I think most agree regular tires handle better. It’s not like properly matched regular tire on F10 is anywhere close to folding or will introduce body roll when pushed. In fact it’ll make your rear end more planted by not harshly "skipping" over the bumps in higher speed turns. In my experience, these are more comfortable, have more grip, quitter, connect you with the road way more than RF, cheaper to replace, don’t wear as fast and don’t bubble as easily on impact. Add “safety” tire inflation kit to your car and you’re still not at the cost of replacing RF tires. And both RF and this kit may, or may not get you to your destination or closest service center. Quote:
Some, maybe all (not sure??) M cars don’t come with RF tires, just safety kit and I don’t think that’s coincidence. Different suspension, sure, but these in theory go faster than “regular” BMWs on daily basis, if safety is concern, shouldn’t they have them too? People have been going high speeds on autobahn and race tracks way before run flat tires were ever considered. I had unfortunate opportunity to ride on busted run flat with my family in the car, and it worked out great. But I also got to experience this specifically due to RF (pothole hit caused a bubble which burst soon after). Had the sidewall damage been any bigger I’d be stuck on the lake, in the woods, same way I now may get stuck if my Continental "ContiKomfort" kit fails me... no guaranties in life, with or without RF. |
06-09-2016, 10:08 AM | #19 | |
Rep 1,472
Both summer and winter, I use 18" wheels and OEM tire sizes. I wanted to go "size down" for winter, it just didn't work out. My winter run flats are Dunlop SP Sport 3D DSST and are great, except maybe for wearing a bit quicker than I'd like. For all season and F10 according to owner feedback new Michelin A/S is quite good and for performance PSS is considered to be the best by most. I'm currently on Bridgestone Potenza S-04 and carry Continental kit in the trunk. Not exactly thrilled about riding with no spare, but given how much I like the car, it's a compromise I chose to (grudgingly) accept. I like these, but they too wear pretty fast. It's ultra performance summer tires, so, it's to be expected I guess. |
06-09-2016, 01:32 PM | #20 |
Rep 1,073
spare really does not take up much room. My RF's are leaving in the fall.
2013 535i M-Sport with 6 speed Manual Transmission, Jet Black on Black, Technology, HUD, multi contour seats, Premium package, Premium HiFi, Non Runflat ExtremeConti DWS 06.............
06-09-2016, 04:25 PM | #21 | |
Rep 15,858
It is one reason why I've opted to stay with run-flats this time around, as the F10/11 wheel is even larger, takes a big part of the F11 trunk. |
06-09-2016, 04:27 PM | #22 | |
///M3 Enthusiast
397
Rep 993
